Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Wont go and screeches when letting off clutch/brake
I have a Huskee LE riding lawn mower (13af660g131) when i put it in gear and let the brake/clutch the mower will start screeching smells like belt is smoking and wont go but acts like it wants to go could this be the pulley? i replaced the belt?
  • 376 Answers
Take off the shift plate between you legs, put it in nuetral, crank up the engine, put speed lever in high gear and slowly let off on the clutch. Everything will work as if in gear, it just won't move. you should be able to see what the problem is. Which belt did you replace and why? Watch the varible speed pulley (the one both belts go around). The bearings may be bad in it and not letting it turn, thus, smoking the front belt.
Posted on Jun 29, 2009
    Problem Solver:
  • 4 Answers
May sound stupid, but from experience, double check the routeing of your belts. Make sure they are under the belt guards where applicable. Been there and done that!
Posted on Aug 07, 2011
    Champion:
  • 205 Answers
Need to investigate, sounds like something is frozen on the belt system. Remove tension of belt and verify everything can turn freely unloaded..
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine cuts off when clutch is engaged
check for a bad safety switch on the clutch/brake pedal try and jump it with a paper clip
Jun 11, 2012 | Garden
Huskee mower wont start
check the safety switches try and jumper the one on the clutch/brake pedal first with a paper clip
Apr 29, 2012 | Garden
Huskee LT 4200 modle 13aj771g031 how do I get the small rear drive belt to go on the pully
Set the brake/clutch. This will disengage the linkage that tensions the main drive belt, allowing you to put it on the pulley.
I hope this is helpful.
Aug 16, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Murray Lawn Mower won't go in gear
my murray riding mower wont pull when i put in gear i dont have a clue what to do,it doesnt seem like its going in gear
May 15, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
434 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
