Question about SmartParts (1DPFSP01) Digital Picture Frame
Dark screen in our Pandigital picture frame.
Our 7 inch Pandigital picture frame shows just a dark screen.When we start the frame,everything is normal but after two seconds the screen goes dark.It is plugged in correctly.Please help.We are using it first time.Thank you.
5 Suggested Answers
  • 11 Answers
SOURCE: can not find the setup file for the smartparts 7 inch digital pic
The setup file is on the frame. Connect the frame to your computer w/ the USB cable. Go to MY COMPUTER. Look for your frame as a removable device and open it up. There is a blue icon called "setup." If you click on it, it will start to download to your computer. If you can't find it, you can download from Smartparts website at this link:
http://smartpartsproducts.com/content/support/optipix/optipixlogin.php
Posted on Jun 26, 2009
SOURCE: Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Posted on Apr 27, 2010
marked
  • 6487 Answers
SOURCE: I lost the manual for my pandigital 7 inch frame.
You can use this user manual since 7 and 8 inch only has one user manual.
http://www.pandigital.net/userfiles/file/Downloads/UG_E-FRC_PAN80XXT_V2_5_01-14-09.pdf
Posted on Jun 20, 2010
  • 1746 Answers
SOURCE: The picture frame still scrolls
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Posted on Jun 11, 2011
Screen shows light with crack, cannot turn off
Internal defect needs factory service. Module inside needs replacing and you cannot do that.
Mar 25, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Instruction_Manuals_For 7 inch cibox photo frome
If you mean the PanDigital DPF701, Retrevo has a link to the manual here: http://www.retrevo.com/support/Pandigital-DPF701-Digital-Photo-Frames-manual/id/7008ag810/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Oct 20, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have no instructions for use
Pandigital doesn't have a manual on their website. However, the FAQ (frequently asked questions) may solve your issue: http://pandigital.net/default.asp?PageID=266&Preview=True . If this direct link doesn't work, start at http://www.pandigital.net/ then click on Support, FAQ and then Additional Pandigital FAQ.
I hope this helps.
Apr 15, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
My Pandigital EReader is frozen, it won't even go into sleep mode.
My pandigital has been frozen on the pandigital novel options for 1 full day. How can i shut it down and read the books I have?
Jan 06, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Dec 30, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
SmartParts (1DPFSP01) Digital Picture Frame Logo
101 people viewed this question
Top SmartParts Photography Experts
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
