SOURCE: My fuji finepix s7000
If the image is blurred on both clean the lens, if it does not fix it then it is probably a faulty lens problem.
SOURCE: Problem in Fuji FinePix S7000 digital camera.
CCD failure image sensor failure
ur camera may be on service
advisory list just mail the fuji film with serial number i am pretty
sure they will repair free of charge it is a manufacturing fault in
some units manufactured b4 2005 u have to email them they will repair
it free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
SOURCE: shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
SOURCE: finepix s7000 new 4gb card not initialized fujifilm cf
The S700 as it came from the factory CANNOT use a 4 gig card. You must go to the Fuji USA website and download the firmware update. You will need to have the program that came with the camera installed, and the cable that also came with the camera. Make sure that you have fresh batteries in the camera. Instructions are on the Fuji website along with the download for the firmware. You are actually going to "flash" the firmware in the camera just as if you were doing a BIOS flash in your computer. Personally, I only use smaller cards and remove the pics soon after I take them. A 2 gig card will hold about 150 full rez pics. Get them out of the camera....don't save them forever on the card!
SOURCE: turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
