HI, it's Jim from Crucial Vacuum!
If your pet brush roll isn't turning then the main reason would be due to pet hair clogged in the roll. Try manually spinning the roll a few times to help unclog it and uncover any hidden debris. Usually a quick cleaning or a little bit of oil by the bearings will have you up and running in a few minutes. However, once the bristles endure too much wear, which is highly likely when it comes to our pets, they will become loose and no longer operate at its peak performance. Trying using a razor or scissors to clear any noticeable hair or debris that you may see.
You can purchase replacement pet brushes and turbo brush tools direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/turbo-air-driven-brush.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
The hair in the bearings. I take pair of needel nose peirs. Its hard,but it only i found
SOURCE: brush roll won't turn on
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
