Singer 8763 Curvy Logo
A
Anonymous Posted on Jul 14, 2014
Does the singer curvy 8763 have a low shank
Does the singer curvy have a low shank
matty_w
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Singer Expert 631 Answers
  • Posted on Nov 20, 2014
matty_w
Singer Expert
Level 2:
Legend:
Answers
631
Questions
0
Helped
183088
Points
809
Yes, your machine takes a low-shank foot. That seems to be the most commonly used type for newer machines.
4 Related Answers
Anonymous
  • 1788 Answers
  • Posted on Dec 31, 2010
SOURCE: I have a singer curvy
I would call Singer at 1-800-4singer and have them direct you to an authorized warranty center. This sounds like an serious electrical problem and should be covered under warranty.
Anonymous
  • Posted on Jul 15, 2012
SOURCE: I have Singer Curvy 8763.
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Sep 06, 2012
SOURCE: can't put back bobbin case in a singer curvy
here's a link for a free manual
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
sylviaivie
  • 1564 Answers
  • Posted on Sep 16, 2012
SOURCE: I cant get presser feet to snap on to my low shank feet holder
Are you making sure the little metal bar is lined up with the little snap on grip?
I buyed a new sewing machine curvy 8763 and when i start trheading the bobbin the needle stats working as well and it starts beeping
Consult your owner's manual. There is a handwheel release that, when loosened, will allow the bobbin to wind but stops the needlebar trying to stitch.
I have a singet curvy 8763 and the needle id dragging in the bobbin wheel. Tried changing the needle and making stitch adjustment.
insert the needle all the way up or, lift the needle shaft and, if the problem persist's andjust the timing of the machine
Needle position
Please correct down position and remove the foot and switch off machine. Then set of the up position applique the needle. After machine On.
Need a open darning and walker foot for my curvy 8763 which should i purchase?
A Curvy isn't an Athena. I have a Curvy and it is a low-shank machine that can use a variety of snap-on feet.
I have Singer curvy 8763 and want to purchase a walking foot for it. Will you advise please
Your machine takes a low-shank foot, and they are very commonly available, either from eBay or Amazon, or any site that sells presser feet.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
