Nao aceita a sena da oi admin
SOURCE: Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
SOURCE: Linksys WRK54G versus WRT54G Firmware
Hi...
The WRK54G is actually a stripped down version of the WRT54G that was bundled with a wireless network adapter and sold under the kit name WKPC54G.
From what you say in your question I gather that you have a WRT54G already in place as your access point, and it is what is connected to your WAN. To use the WRK54G as a range extender repeater you should do the following:
1. Turn off DHCP
2. Turn off NAT
3. Assign a fixed IP that is in your Class C Block
4. Define the WRT54G as the Gateway
With this configuration it now should function as an extender/repeater, and any clients connecting to it will be serviced by the DHCP on the master router.
I hope that this helps.
SOURCE: Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
SOURCE: Forgot Access Point Password
All you have to do to reset the password on the router is to reset the router. You just have to find the reset button and hold it for about 15 seconds. If you have any problems with reseting just look at this pdf.
ftp://ftp.linksys.com/pdf/wrt54g_ug.pdf
SOURCE: My wireless access point SMC
Thank you cgahongayire.
Follow these steps to retrieve the wireless key:
1) Connect a computer wired directly to your accesspoint.
2) Assign a static IP on the computer with the range of 192.168.2.x (x is any number from 3-253).
3) If it prompts you for a user name and a password, user name is admin and password is smcadmin and click Login.
4) Select Advanced Setup. It will give you the window for the access point.
5) Select Security under Radio Interface 2. You can see which security is set on your AP. If it is set as WPA, the shared key is your network key. If WEP, the network key across the selected key is your password.
Take note that these instructions are if the IP settings of the Wireless AP have not been changed. If it is, you have to ask what is the IP first.
