Question about Toto Home
Keeps on runing
Keeps on running water does not turn off
  • 224 Answers
Either the flush valve needs to be adjusted so that the float is below the overflow tube, or your flapper is not sealing or getting stuck. The fill valve either has a float or a ballcock. On a ballcock there is a screw at the top of the fill valve that will lower the arm of the ballcock. On a float, a small clip connects to a rod next to the float, pinch and pull down to lower the float. There is a plastic screw at the very top for fine tuning.
Posted on Jul 04, 2009
Water keeps going in to the wash but not fill its draining
Check if you installed the hoses correctly. It must go up first then down about 600 mm at least.
Jan 09, 2014 | Kenmore Washing Machines
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
After Eng is turn off A/C & heater fan keeps runing dranig
The fan runs off a module incorporated inside the blower fan motor. The motor assembly will need to be replaced for its all electronic inside
Jun 22, 2010 | 1996 Buick Park Avenue
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
The ice machine it beeping 3 time. I reset the little white button on the pc broad. It run for a while and the beeping sound come back. I know if I hit on the F/S with my crew driver it turn to diffrent...
sounds like you may have more than one issue. Tapping the float switch indicates that it is sticking. This will keep the water coming in and the unit will not go into it's freeze mode. Go to the Hoshizaki web site for how to remove and clean. It's really not that hard. If you can't find it, I'll walk you thru.
With the machine turned off, is there still water running? IF so, the water valve is also stuck in the open position and letting water in. This could cause it to have long freeze cycles and possibly freeze up.
Start there and let me know if you need any more help.
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Feb 27, 2010 | Freezers
Water keep runing into the machine and exceed the required level setting. the machine will not start to washing is it that the water level in to high or does the water level setting control the washing...
put the washer on warm setting,start to fill washer,turn washer off,if it still keeps filling then you have a bad water inlet valve,if it turns off then check the water level hose from the head of the washer to the side of the outer tub,make sure both ends are on-mike
Jan 27, 2010 | Washing Machines
The dish washer runs but does not pump the water out sounds like the pump is runing and nothing seems to be plugged
Dec 31, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water keeps runing throught the GMax 580
You will need to replace it with a fluidmaster.
Sep 21, 2009 | Toto Toilet Onepiece Ultramax ...
Water keep runing
There are several possibilities. Most likely is a bad valve. Unplug the machine. Is the water still running? Valve is bad. Replace it.
If the water shuts off, the timer is malfunctioning.
Jun 08, 2008 | GE Washing Machines
Home Logo
450 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
