Question about InFocus LP 70 Multimedia Projector
Infocus LP 70 projects a blurred display
We have a Infocus LP 70 projector which has suddenly started to show up the display as a blurred image. The source image from the monitor is fine and the projectors display glass is clean. Re-focusing via the manual knobs has no effect. I'm not able to view the menu and reset to factory defaults or fix the image if this is the issue. Any ideas?
Satpaul
  • 2,237 Answers
If it's pixelated, it's an electronic issue. if it's evenly blurred, it's an optic issue. was it dropped on the lens? see if the lens is hard to turn or is not sitting properly in the projector.
Posted on Jul 08, 2009
  • 138 Answers
Go to control panel and reset hardware configs that way.
Posted on Jun 29, 2009
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
PAL support
Yes the LP70 and the LP70+ both operate perfectly with a PAL source. Also the will operate just fine using 220vac 50hz too.
Cheers
May 31, 2008 | InFocus LP 70 Multimedia Projector
Blur Image
Hi there
If it is a DLP Projector it could be the Packlight Pipe Module that needs repairs.
Basically this part has 4 small mirrors facing each other and this normally happens when one of the mirrors come loose.
Very cheap to repair
Mar 31, 2008 | 3M Projector lamp Projector Lamp
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
InFocus LP 70 Multimedia Projector Logo
939 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
