Question about Kenmore 22422 Top Load Washer
Kenmore 80 Washer spins sometimes
The washer only spins some of the time. When it does not, I can manually spin the tub and hold down the switch and it will spin like it should but I have to get it started. Could the clutch be going out? How involved is it to replace? Thanks.
  • 351 Answers
Spin basket drive is out the part is around 100 my experience i can replace in 20 mins
Posted on Jun 29, 2009
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Wont drain or spin
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it useing the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down .if you have to replace the lid switch for it to work properly or bypass the lid switch it needs to be from under the console .do not drop screws in between the tubs
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series won't agitate
You will need to check you water level switch. Sound like it is bad or has something clogging it. You can test it like this. Find the tube that runs from the back of the level switch down to the outer tub. Unplug it from the tub. Now turn machine on so that it will start to fill. Now blow pressure into the tube. If it does not cut the water off, you have a bad switch. I would think it's bad. I see them about 5 ir 6 times a week.
Please rate solution if helpful.
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 series. did not spin
most common problem is either the lid switch (made no sound) or the drive coupler(sounds like its working but no spin) also check for anything holding tub(nail trough basket jamming tub etc.)
Jun 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Kenmore washer
Lori, first check the lid switch, if it's broken, it won't spin or drain. Put it into spin and hold the switch down, see if it drains. Check that first...Catriver..post back.
Feb 23, 2007 | Kenmore 20722
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
114 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
