Question about Microsoft Wireless Optical Desktop Comfort Edition
Locked Keyboard? I've had this keyboard and mouse set for about a year, maybe a little less, and never have I had any trouble with it until today.  My computer was left running over night, this morning when I went to use it my mouse was frozen and my keyboard was as well.  I figured a restart would solve it, as all computers tend to freeze now and then.  I restarted my computer and only the mouse works properly.  On my keyboard, only the hotkeys work (the ones for messenger, mail, documents and such,) nothing else.  Is there a chance my keyboard got locked somehow?  The batteries are fresh, I've reset the wireless channels, I've unlplugged and replugged the usb cable for the wireless reciever, I've tried unlocking and locking the numlock and caps lock and f lock...the num and cap didn't even respond. What else can I try?  Any help is greatly appreciated!
    Problem Solver:
  • 11 Answers
Re: Locked Keyboard?
I don't know if this would help however I had a problem with my keyboard earlier today. What I did was restore my computer to an earlier date. In my case I restore it to yesterday date and it worked.
Posted on Nov 10, 2007
0 characters
3 Points
The problem with my microsoft 6000 v2.0 keyboard is this. I have changed batteries (4x with brand new), the light on keyboard comes on, then after about a minute, the light goes off and keyboard does not...
Not to sound patronizing, did you push the buttons in the order it requires you to? The sequesnce and timing is important. Also, the keyboard and mouse have to be pretty close to the receiver, and the receiver need to be almost completely in a direct visual line with the devices on these MS keyboard desktop sets. I had a lot of trouble with mine until I put the receiver within 1-1/2 to 2 feet of the keyboard and mouse. Next time buy a logitech top-of-the-line set and you will not have this kind of trouble. I no longer have trouble with my 6000 desktop set, though, just in case you are wondering. I use the Logitech set on my newer computer and the 6000 on the XP .
Hope this helps.
Sep 16, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
My keyboard and mouse are locked
press window key + R type devmgmt.msc see if your keyboard and mouse drivers are working properly or not if you find yellow warning sign it means ur drivers has become corrupt and now its time to reinstall ur drivers :-)
May 20, 2010 | Dynex Multimedia Keyboard
Dell keyboard locked up
Dear Sir,
PLzz folow this step to unlock your keyboard
Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    My dell wireless keyboard just stopped working. I
    if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
    Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
    Wireless desktop 6000 keyboard problem
    Check the inside of the battery chamber to see if there is corosion on the spring or front pip for the + ve.Batteries leak ands should be chaged every 6 months regardless
    Jul 27, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
    My inspiron 1525 has a keyboard problem everytime i am typing it jumps back do you have any idea what's going on?
    I've been struggling with this issue as well. I type really fast so I thought i was inadvertantly hitting the touchpad and moving the cursor. Maybe, maybe not. But today I discovered that changing one of the dafault settings for the touchpad has eliminating the jumping cursor trouble and I can type fast again without constantly checking my screen to see which line I'm actually typing in.
    Here's what I did: Go to the control panel and the mouse and click on the icon for the touchpad and uncheck the touchpad setting "tap to click"
    I also put my speed and sensitivity about in the mid-range. (Another suggestion that didn't work was to make my touchpad less sensitive).
    Happy typing!
    Feb 23, 2009 | Dell F3534 Touchpad
    Keyboard not working
    To connect the keyboard or mouse to the computer, you must connect the wireless device through the USB port and get it to hold a good connection. You do not have to install any devices to use these products, they automatically work when you plug them in. When it says that the device is recognized, you are ready to use it! If you have a desktop, you can also plug the wireless device to the mouse port. The keyboard and mouse work properly up to 5' away from the connected wireless device. If you can get the wireless device to work properly, you should have no troubles with the product.
    Dec 29, 2008 | Innovations kb985w RF Wireless Keyboard
    Wireless key board
    Have you tried re-setting the frequency for one of the devices? simply click the button on the infra-red unit then click the button on the back of keyboard and notice the infra-red unit stopped scanning.
    Oct 23, 2007 | Logitech Cordless Desktop EX110
    Microsoft Wireless Optical Desktop Comfort Edition Logo
    493 people viewed this question
    Top Microsoft Keyboards & Mice Experts
    micky dee
    Are you a Microsoft Keyboard and Mice Expert? Answer questions, earn points and help others
