Question about Lexmark Z12 Printer
My Lexmark Z12 Prints in triplicate. The same line
This problem began immediately after I had a paper jamb. When printing once before, I noticed a sheet was beginning to jamb. I thought I'd help it by pulling it through a little. That unjambed it, but then all future printing resulted with the following problem.
My Lexmark Z12 Prints in triplicate. The same line in overlapping offset. The printer prints a line then scrolls only about have a line down then prints the same line again and then again. Printing three times each line offset about half of a line. The results are a blurred triplicate of the same line.
    Habit-Forming:
    New Friend:
  • 28 Answers
I would troubleshoot with the following steps:
1) Turn off for 5 minutes then power back on
2) Reseat the ink cartridge(s)
3) Uninstall / Reinstall printer from computer.
4) Test print
Posted on May 09, 2017
    Habit-Forming:
    New Friend:
  • 81 Answers
Check out @ http://lexmark.printertechsupportnumbers.com/ I think this will helpful for you.
Posted on May 05, 2017
  • Julia Wood
    Julia Wood May 07, 2017
    Turn it off, for a minute. -Re-set it's brain. Then turn it back on.
SOURCE: Lexmark X3350 printing
i just fixed this problem.  first i bought a new (remanufactured 3rd party) cartridge off ebay and found it wasn't working either.
there are cartridge cleaning instructions in the troubleshooting help section that show you how to carefully wipe clean your cartridges.  follow that, it solved my problem.
Posted on Feb 11, 2008
Ajkill
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
  • 7 Answers
SOURCE: Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Posted on Dec 04, 2008
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
rulds2008
  • 3866 Answers
SOURCE: paper jam/ printing problem
I have this printer and when this did it to me like its doing to you the FEEDER had to be replaced. Now you might want to see if all the rollers are rolling and nothing is in the paper path. Also check you paper weight and size and adjust accordenly. A new feeder is like $27 bucks and you would have to go 3rd party to get it. I got mine from a USED lexmark someone was saling off ebay for my fix.
Please be considerate and leave a ratings and postive feedback for your free answer today.
Posted on May 26, 2010
My lexmark printer prints a few lines properly, and then it misses the next few lines, or only partially prints them. How do I correct this problem?
On your inkjet printer, start the Lexmark software,
and run a "print-head-cleaning-cycle", since some (not all)
of the ink-jets that shoot the ink onto the paper are CLOGGED.
Oct 07, 2010 | Lexmark Office Equipment & Supplies
LEXMARK z12 IS PRINTING SAME LINE TWICE LIKE
uninstall/reinstall the printer software and drivers
Sep 14, 2009 | Lexmark JetPrinter Z12 color InkJet
My printer sounds like it's printing, but the paper comes out bla
Most likely cause is the ink cartridge needs replacing / refilling. Did it stop printing part way through a page?
Aug 17, 2009 | Lexmark JetPrinter Z12 color InkJet
Lexmark, paper jams and prints in same place, over+++
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Compaq Lexmark Color Jetprinter Z12 InkJet
Lexmark z12 printer
Most likely your printer's cartridge settings are incorrect. You possibly have a black and white cartridge in your printer but your computer settings are for a color cartridge. First verify what type of cartridge is in your computer. Then find the printer your are using installed on your computer. If you OS is Microsoft then double click on the Lexmark z12 and click on printer and then properties. Another window will pop up. Click on Cartridge Maintainence and then click on Verify/Change Cartridge. Hope this solves the problem. It worked for me.
Sep 30, 2008 | Lexmark JetPrinter Z12 color InkJet
Prints a few lines, then blank
This is worth attempting to discuss with Lexmark's Tech Support line. Or take a look at www.fixyourownprinter.com
May 17, 2007 | Lexmark X5150 All-In-One InkJet Printer
Printer double to quardruple prints each line over each other
reinstall software o actualizalo...tambien puede ser un virus o inestabilidad del sistema operativo
Jan 13, 2007 | Lexmark JetPrinter Z12 color InkJet
Lexmark Z12 Printer Logo
167 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
