Palm Tungsten E2  Handheld
Problem for Palm Tungsten E2 (Multilingual) Handheld
Touchscreen no longer works
By BSAnalyst on Nov 07, 2007
I have a Tungsten E2. The touchscreen was off, so I tried to recalibrate the touchscreen using the calibration utility. The utility did not work and now I have no touchscreen capability at all. I can get into the calibration utility, but it doesn't accept touch input.
Same Problem
May 14, 2008
-   I am experiencing the same issue following a battery replacement. I have performed both a soft and hard reset (many times). The hard reset screen never appears; the Palm Logo appears regardless of the reset method. The Digitizer appears on the screen, but does not recognize any input. From there, I can do nothing but power off or reset again. **HELP**-   THINKNPLUS
May 05, 2008
-   I have the exact same problem and resetting the PDA didn't work-   Guest
Mar 28, 2008
-   I also tried both of these on my Tungsten E2, and still can't get out of the recalibration screen. My screen no longer accepts any input at all.-   Guest
Dec 04, 2007
-   I have tried both of these steps and mine still will not recalibrate.-   leaannturner
Best Solution
posted on Sep 05, 2008
Very Helpful)
danielbrown
Rank: Apprentice
Rating: 100%, 1 votes
Well watch this video and after you follow the directions get the screen and find the glass like cover and remove it from the screen bend it in a very lightly way, then put it back on and put the PDA back together and BAM.
Was this helpful?
Yes
No
Solution #2
posted on May 14, 2008
Helpful)
THINKNPLUS
Rank: Apprentice
Rating: 85%, 1 votes
I resolved my TOUCH SCREEN PROBLEMS (Following a new battery installation and charging, Touch Screen would not respond; after reset, Calibration screen locked up and did not respond):
1) The power charger must be unplugged.When A/C Power cord is attached, calibration will not respond/proceed.
2) The battery terminal wire must not rest on the internal boards. I found another troubleshooting board that mentioned insulating the wires with tape. It worked. I also noticed that if the back's lower two screws were too tight, it also locked up the Touch Screen, perhaps causing too much contact. (It doesn't need to be loose, just not tight.)
Was this helpful?
Yes
No
Solution #3
posted on Nov 09, 2007
Somewhat Helpful)
MrJodie
Rank: Wiz
Rating: 83%, 89 votes
Sounds like the digitizer is so far off that the input won't align correctly. This would, most likely, be confirmed if you get any response when you tap the touchscreen (moving cursor, beeping, etc). You'll need to try a soft reset using the little reset tool in the end of your stylus, or a paperclip if you don't have it. Press and hold the reset button inside the unit (located in the back panel) for a few seconds until it chimes and you see the Palm logo. Then try the Digitizer again to calibrate.
Now, if that doesn't work, you may need to factory reset the device. THAT MEANS YOU LOSE ALL YOUR DATA, so do whatever you can to get it backed up. You simply hold the reset, then press and hold the power button for several seconds. Instead of the standard Palm logo you'll see a prompt asking you to press up on the touchpad, on the front of the unit, to reset it to factory default. It will then run you through the initial setup routine to set the date, time and finally calibrate the Digitizer.
Best of luck and let us know how it turns out.
Was this helpful?
Yes
No
Solution #4
posted on Dec 21, 2007
Somewhat Helpful)
biswebdotws
Rank: Guide
Rating: 70%, 2 votes
I have owned my Palm for about 1-1/2 years and at least twice I had to do that (power/reset) as my touch screen eventually quit working and I couldn't get the digitizer to fix it either. So far this is the only solution I have found that works.
I think this is a bug in the system, but PALM has not yet posted any info or a patch to correct it.
Was this helpful?
Yes
No
Popular Solutions for Palm Tungsten E2 Handheld
Questions and Unsolved Problems for Palm Tungsten E2 Handheld
Do you recommend Palm Tungsten E2 (Multilingual) Handheld?
Answer
Answer
i can't access my list of pdf files. I need to delete some files but the application jumps from the... (More)
Answer
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the... (More)
Answer
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back.... (More)
Answer
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Palm Tungsten E2 Handheld:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
