Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
If I reformat the disk in my camera do I loe all
If I reformat the CF card in my camera do I lose all my pictures I already took? What does reformating do?
Yes, formatting the card will erase all the pictures on a card. Formatting initializes the card with an empty file system, which can be useful when a card becomes corrupted.
Posted on Jul 01, 2009
My Nikon D70 has stopped reading 3 of my CF Cards. sometimes it says CHA, sometimes it says FOR. EIther way, it will not let me take a icture or view the pictures already on it. I have triied...
Hi vazquez_jami,your camera have some trouble in memory compression circuit (the worst) or pin connector/soldering defective or bent in CF connector.
Regards
Mar 21, 2011 | Nikon D70s Digital Camera
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Im getting a Err 002 which means something is wrong with my CF. I have had it for 5 years and no problems until now. I tried to reformat but my camera will not let me into the menu option with the CF in...
I agree the problem is the CF card. I'd like to add that it must have several back to back corrupt files to be refusing formatting. As much as I teach/lecture not to do this I also agree that to save that card place it in a memory card reader and format the card in the computer. Check before hand to see if there are usable pictures and load them to a new file folder before formatting. Once formatting has been completed in the computer check that all pins are in correct and serviceable condition in the card reader slot in the camera before install it back into the camera. Then reformat the CF card in the camera. Each time pictures are downloaded to the computer a CF card should be formatted.
Deleting pictures just causes a huge amount of problems if done repeatedly in favor of formatting.
I'm including some diagrams to show where the formatting mode is located on your camera.
Best of luck
Hope this helps Happy New Year
Jan 01, 2011 | Canon Digital Rebel / EOS-300D Digital...
Have mercury vq2220-- took pictures before getting sd card. now it tells me i have to reformat sd card. will it erase all the pictures already on it. (I donot have instruction book and cant retrieve the...
Reformatting the card will delete everything on the card HOWEVER I'm not sure about the ones already saved on the camera. Your camera has a USB connection, it may be safer to move the pictures to a pc before you try anything.
Good luck,
Dec 28, 2010 | Kobian Mercury 3.1 Deluxe Classic Digital...
I have a 2 mg scan disk in and I took about 75 pictures. I took the disk out and downloaded it to my computer. When I put it back in the camera it keeps on telling me I have to format the disk. If I do...
Sounds like you didn't use the "safely remove hardware" function when you removed the card from the camera and corrupted the card. Now, your camera doesn't recognize it. If the pictures have been downloaded to your computer, why are you hesitating to format the card in the camera? Sure, this will erase it but it will also return it to usability
Sep 29, 2010 | Cameras
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
I took a picture wihtout a CF card in the camera
When you take pictures without the internal card , they get stored inside the camera internal memory (usually 8 or 16 MB only).
Connect the camera to a computer using a data cable, without putting any memory card inside the camera. The camera internal memory will be displayed as a new external usb disk on computer.
Apr 18, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Feb 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My CompactFlash card is no longer recognized by my computer (Sony Vaio notebook w/Windows XP home edition)
It isn't clear from your description, but are you inserting the reader into your USB port, and *then* inserting the CF into the reader? If so, try reversing this -- insert the CF into the reader, then insert the reader (with the CF) into a USB port. It is possible that your PC is only looking at the reader once (when it is inserted) and not finding a CF, then ignoring the CF once you insert it. If your camera can read and write to the CF, then it is unlikely that the CF is damaged. Since you have determined that the reader is ok, and since your PC recognises the reader, it is unlikely that it is a USB driver problem. Similarly, it is unlikely that it is a physical problem with the USB port, or the pins in the reader or the CF card.
Mar 03, 2007 | Canon PowerShot A50 Digital Camera
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
