Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My mower keeps blowing the 20 amp fuse that is on the red circuit going to the ignition switch. If I put a new fuse in and turn on only the head lights the fuse will blow just by steeping on to the mower. How can I track down where the short is?
  • Mike McDowell May 11, 2010
    WIll the fuse blow if the headlights are switched off?
  • 472 Answers
Ck the wires going to yhe head lites theay could be frad and shorting out
Posted on Oct 01, 2009
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
Lawn tractor problems
What brand,model and year, If Craftsman check your owner's manual. Mine takes a 30 amp.
Feb 07, 2012 | Garden
Where are the fuses for blinkers
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
I hope this helps :)
May 16, 2011 | 2004 Jeep Grand Cherokee
Lost owners manual and was testing fuses at the junction box. do you have any info. as to what each fuse controls. i lost my dash controls ex. speedometer oil guage . its 1999 jeep cherokee ltd
Here is the diagram you were looking for, hope this helps :)
May 16, 2011 | 1999 Jeep Cherokee 4WD
20 AMP FUSE BLOWS WHEN IGNITION IS SWITCHED ON IGNITION SWITCH TESTED AND OK
something connected too ignition sdwitch has short to ground. remove all fuses except 20amp that blows turn on ignition see if blows. if not replace one by one till it does to isolate circuit. which fuse is blowing and where is it located.
woodysmechan kiesha76@hotmail.com
Mar 10, 2011 | 1999 Suzuki Vitara
I need a copy of the fuse box underneath the dashboard of a 2004 jeep grand cherokee lorado limited edition
Here You are...
Grand Cherokee fuses
1999-2004
Junction Block
F1 -- -- Spare
F2 -- -- Spare
F13 -- -- Spare
C3 -- -- Spare
Mar 07, 2010 | Car Audio & Video
20 amp fuse inline fuse blows when switching to head lamp position on ignition switch. I need the schematic for the electrical systen
check to make sure the head light wires aren't touching exhaust that is the most common problem if i can further help e-mail me wade at wadembly@aol.com
Jun 25, 2009 | Garden
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
Wiper fuse keeps blowing intermittently.
It looks like the wire circuit for the wiper motor is touching the car body when shaken so the only thing you can do is shake the wires and terminals yourself while engine is running then maybe you can pinpoint where the earthing is.
May 08, 2009 | 2001 Hyundai Accent
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
2,358 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
