Question about Maytag Neptune MDE4000 Electric Dryer
Dryer,timer switch won'tmove & cool air only.
MDET336AYW electric dryer.Timer switch will not move from the position started in,runs forever,will not shut itself off and only blows cool air.Wondering if both the timer and element need replacing? Thanks!
  • edegraf Jun 29, 2009
    Joe...silly question I am sure, but what exactly do you mean by times? Thanks!
  • edegraf Jul 02, 2009
    Thanks! I appreciate your help!
  • 10,865 Answers
Begin by replacing the times. Then you will most likely find that you are back in business.
Posted on Jun 29, 2009
  • Joe Hogan Jul 02, 2009
    oops sorry for the typo. i meant timer. Begin with the timer. Then let it run. You will most likely find that the element will function when the timer tells it to.
  • 351 Answers
The timer will not move if it does not heat up! we need to check and see if the element is getting electric if not then its most likely the thermostat. whirlpoolpartssurplus.com mark
Roper electric dryer wont start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Feb 09, 2016 | Roper Dryers
Dryer won't hold run position
Most likely problem is a bad door switch. This is a common problem. Another possibility is a bad timer switch.
Jan 14, 2012 | GE DPSR483EA Electric Dryer
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Dryer will start run 5 minnutes shut down
After the dryer has been started to run, the motor will stop only when at least one of the motor feeder circuit wires is disconnected. The main feed line is routed through the timer while the neutral feed line is routed through the door switch. Hence, the problem is either the timer or the door switch. But the dryer shuts down 5 minutes after it is started and this signifies a dead spot in the timer that discontinues the main feed line shutting the motor down and also the timer motor. If the timer stops at the same point, then the timer is faulty and needs to be replaced.
Replacing the timer is an easy task that an average handy housewife can do. Just make sure the power to the dryer is disconnected prior to servicing to avoid the risk of electric shock.
Pull the timer knob off the console then remove the screws attaching the console rear panel to the console and move the panel away.
Disconnect the wires from the timer terminals one at a time then connect it to the new timer to avoid swapping out the wires.
Remove the screws securing the timer to the bracket then remove the timer and secure the new timer in place. Put the console rear panel back into position and secure it with the screws.
Apr 07, 2010 | Whirlpool WED5200T Electric Dryer
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Neptune Dryer Time keeps going forever
your problem is most likely an issue with the start button. if it is stuck, the dryer will keep running even though it has passed the off position. your start switch probably needs replaced. Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer continues to run.
barnardfl
look for a cool down thermostat on the fan body. this thermostat opens on cool, and is in the motor circuit, not the heater circuit as the other thermostats are. After the timer switches off the heater and motor, this thermostat keeps the motor running until the temperature drops below ~45C, drawing unheated air through the dryer. when they fail they weld closed and do not switch off
aaaa3786
If knob does not move, there is likely a stripped nylon gear in the stepper motor for the timer
timer motors cost $~14 if available in your area, and attach to the timer body by two screws
rebuilt timers can be purchased at many parts stores, labelled as almost anybrand as many are interchangeable $~40
new timers are around $~60
Oct 09, 2008 | Whirlpool LER4634J Electric Dryer
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
245 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
