Question about Kenmore Dryers
I have a Kenmore 96274100 dryer that won't start. What could be the possible problems?
  • lampehome Jun 30, 2009
    In looking for the thermal fuse, I saw that the wire from the hi-limit thermostat to the operating thermostat was burned through. The hi-limit thermostat is shot and the wire needs to be replaced too. Is it likely any other parts are bad? The thermal fuse, the operating thermostat?
  • 351 Answers
The little white thermal fuse in the back of the dryer you can connect its wires and see it will run. i can ship you one today! whirlpoolpartssurplus.com mark
Posted on Jun 29, 2009
  • Mark Nichols Jun 30, 2009
    sorry have got ill this afternoon, yes i would still consider that because it only handles the heating element and the element got to hot and burnt that and probably took out the safety i would check out the dryer vent as well
Kenmore 600 series dryer won't start. Interior light comes on
Strong possibility your dryer fuse has melted due to a lint buildup in the filter chute of your dryer. Check out my photos of a dryer tuneup I did last summer. ROPER DRYER TUNE UP
SERVICE MANUAL AND MORE PHOTOS
Jun 16, 2012 | Dryers
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
heatman101
Aug 11, 2011 | Dryers
My series 80 Kenmore dryer won't start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
Whirlpool made for Sears (Kenmore) HE4 Elite SmartHeat QuietPak9 will not respond to commands, eventually puts 20 on the time screen and the lint light comes on, won't start, won't run, checked...
send the model number,open the door look around the opening where you put the clothes in you should see a tag there.if you unplugged it and it worked then it's not any of the t-stats or door switch most likely a board issue or something to do with the cord from moving it,when you unplug it and plug it back in your resetting the board so this is what it sounds like but can't tell if you even have a board without model number.
Jan 14, 2018 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Won' dry----
gas or electric? gas units have coils that activate the gas valve, if thats your concern. If it's electric, one of several possibilities exists. Either it;s the heating element, or you have a fused service disconnect box that's blown one of the fuses, or a high limit thermostat is broken. You can check all these things with continuity tester and replace whichever is bad.
Jan 11, 2009 | Kenmore 62602 Electric Dryer
Dryer belt replacement
To replace the belt, you have to take the front off the dryer and lift out the drum. With the new belt, place it around the drum and with the drum in place put the excess belt through the idler pulley or bracket (depending on your model), then around the motor pulley. You push the bracket or idler arm toward the motor to get the "loop" of the belt around the pulley on the motor. Hope this helps! Paul Hoffmanns
Jun 17, 2008 | Dryers
Dryers Logo
262 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
