Question about JVC AV48P777 Television
Vertical jitters on picture - JVC AV48P776
I have a JVC AV48P776/777 TV that started showing green vertical lines with a line flashing continously across the screen. Turned the TV off. When powered on again, the TV now has vertical jitters on the picture. Any suggestions?
  • steelodon Jun 29, 2009
    What would this cost to repair?
    Champion:
  • 205 Answers
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Posted on Jun 29, 2009
  • Rich Elliott
    Rich Elliott Jun 29, 2009
    Advice, call your local tv service shop and inquire. If you have resources to deliver the TV to the shop it will be cheaper that a service call.
    I would expect this to fall into the one hour minimum service fee.
    But you can call and explain that your seeing retrace lines in your tv and they should be capable of estimating the repair for tweaking the high voltage. There is an outside chance that the TV is aged to the point where it will not improve with all the high voltage available.
    It's a judgement call.
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
Horizontal line
hi,
ur tv has problem with vertical scanning section. may be dry soldering or vertical output ic faulty.
u can easily find out the vertical section on ur tv. for that u have to open ur tv. u can see a coil is fitted on the picture tube neck. there are four lines coming from the neck, of which two will go to horizontal scanning section and the remaining two will go to vertical section. follow the two thin wire normally in color green and yellow. it will go to a socket in the main board. trace the track from that socket in the main board . it will lead u to the vertical scanning section. check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. if u need more assistance feel free to contact through fixya.
regards
Ajin
Apr 11, 2011 | JVC AV-20020 20" TV
I have a JVC AV-32950 and have lines running across the top 3 - 4 inches of the picture. The picture also goes black on occassion and I have to hit the top of the TV to get the picture to come back. While...
It may be a dry solder point somewhere near the vertical IC. First take look at the solder points and if you found cracks pls resolder it. if the lines continous you have to replace Caps near the vertical or circuit.thank you
Nov 23, 2009 | JVC AV-32950 TV
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV48P777 Television Logo
437 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
