Question about Garden
Does the warranty expire when it changes owners
I purchased a 5+ year old troy built tractor from a guy who just had the transmission re-built at an authorized troy built service shop in the fall of 09', and over the winter the case on the t-mission blew again. He told me he, and I realize he wanted to get rid of it, that the t-mission should still be under warranty, because it was repaired at an authorized repair shop. All I have at this point is the service statement from the repair shop (no prof-of-purchase). What should be my next move to avoid the $600.00+ bill for a re-re-built transmission from Lennon's in Gloversville,NY and is it worth $600.00???
  • 513 Answers
The warranty should still be good if you cant get it warrantied maybe the guy you bought it from can get it warrantied try that & see but why is the tranny blowing is the question if i can further help let me know thanks wade
Posted on Jul 04, 2009
New tractor power loss on a grade, deos not develop full speed
Hello Joe
If you have an automatic or hydrostatic transmission then you have a lemon, which means once the oil heats up in your transmission it thins out and clutchs and swash plate have no grip on the drive system which is hydraulic pressure needed to hold on the shaft and axles this happens all inside the transmission you cant see it but you can tell when going up slight hills and when you have the blades engaged it crawls like a turtle get you warranty out Joe..... dont touch anything that may void your warranty..... just call service department they will send service man out to your home even after that keep a good eye on your tractor since its still under waranty for further problems.
Joe your 20 year old craftsman had a better built ****** by sears and you probably had a 6 speed or five speed even hydostatics were good too,they dont have much problems except belt slipping its an easy fix this new tractor u need service man right away.
Joe
Oct 08, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a troy Built Bronco ridering tractor with a Kolher courage 18 597cc motor. When I go to srtart it turns over slow almost like a vapor lock, I have replaced the battery and has full charge. I h
The engine will have a valve lifter on the cam shaft to reduve the compression on start up if the valve clerances are too wide the lift will not work making it very slow to crank.
Sep 12, 2012 | Troy Garden
DOES TROY BUILT PONY MODEL # 394358 HAVE A OIL FILTER 17.5 HR 42" CUT
Your owner's manual indicates to change the oil and replace the oil fitler on page 19 as part of the regular maintenance schedule. Whether or not your exact engine application does indeed have the filter is the engine manufacturer's option. Here is your manual.
http://www.troybilt.com/wcpics/TroyBiltUS/en_US/wwcm/769-03502.pdf
Apr 22, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Troy built lawn tractors, belts
You may have a pully that is not spining freely. Or you may have a pully that is not positioned straight. Ariens had a problem with that. so your troy built may have the same.
Apr 19, 2010 | Garden
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
