Question about Tools & Hardware - Others
Hello i have a vector sander/polisher,and it doesnt work right side up.If i turn it upside down it runs fine,but when i turn it over to use it,it short out.Is this a frequent problem.And the place i brought it from is no longer in business.Can you help me?
  • 47 Answers
Sonds like the brushes are not making contact, on the side of the motor body, there is two plugs, remove to see if they are worn out.......
Posted on Jun 29, 2009
Makita 9227c problem will only run upside down. I
...Jon sounds like broken cable in side the wire its self usually were the cable joins to the handle its self if u move the cable about u will b able to check this out wihlst running it .. i had this on mine i cut out the bad bit and re wired the it been fine now 1 1/2 years now
Sep 13, 2013 | Makita 7" 9227c Buffer Polisher Sander Kit...
No powerto sander. Cord is good,switch is good and brushes are long
It sounds to me that you have used the sander a lot and the vibration has broken a wire or it's about to break on the field windings. The brushes you need to look at to see if worn. But I kind of think wire problem. I had this happen on mine and opened it up to find this is what happened. The sander would be turned on and would not operate until I turn upside down and it would work. This is great if you are sanding upside down but this is just a sign that you are on borrowed time as this will eventually not turn on at all. I was able to fix mine with new wire crimp connection and solder with heat shrink material. If not you can order new field winding if this is what is wrong. Cleaning up the sander won't hurt either. You might want to see what a new sander will cost vs. part. Good Luck!
Aug 23, 2012 | Dewalt Sander,random Orbital - DEWALT
Could you please tell me what sandpaper goes on the Mouse sander/polisher model # MS500
ok this easy go to the hardware store and ask for the sandpaper to fit your sander, black & decker make sandpaper specifically for that sander. now depending what job you want to do will determin what grade you want sand paper works like this the higher the number on the paper the finer it is so for example 80 is very coarse you would use that for eg stripping thick paint on a door but 2000 is very fine and is used for eg sanding varnish between coats. ok hope that helps let me know how you go.
Mar 11, 2011 | Black & Decker Mouse Sander/Polisher
Model no 333 wont start unless i turn it on its side?
Aug 15, 2010 | Porter Cable 332K Quicksand Random Orbit...
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Where can i buy new brushes for the vec236
I believe this is a "throw away" tool :o( if not, there'll be a screw-type "door" in the chassis of the grinder...get the brushes out and try your local ACE or TruValue hdwe.
Good Luck
Jun 14, 2009 | Vector VEC236 7 Inch Waxx Pro Kit VEC236
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
Tools & Hardware - Others Logo
304 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
