Question about RCA Universal Remote Control
Booting problem I just in stalled an maxtor ata 250 gig in my dell dimension 4400. I used partition magic to copy partitions to this drive. It is connected via cable select. When I hook it up to replace my old drive it will not boot. I have a dual boot XP2 system and use boot magic which doesn't  recognise it as bootable. Can you help me? Thanks. Terry
  • trrec Nov 07, 2007
    I paid for premium service. Why am I in the free forum?
  • 537 Answers
Did you select to make the boot partition active? Most of the drive copy/image/partition programs have an option for this.
Posted on Nov 07, 2007
you can technically "rename" any partition but you cannot change drive letters on the boot partition c:. I would uninstall some programs from the c: and reinstall them on the f:. There are 3rd party products like partition magic that let you re-size partitions but the good ones are not free.
Apr 06, 2012 | Dell Dimension 2300 PC Desktop
Booting problem
I'm thinking the boot sector or master boot record was not written to the new disk or is corrupted.
Try running the recovery console from the installation CD and take a look at FIXBOOT and FIXMBR
Nov 07, 2007 | Maxtor (6L250R0) 250 GB Hard Drive
Ran out of disk space on my Vaio desktop PCV-RZ24G. 120 gig drive but c formatted to 19 gig. purchased a WD 250 gig and did a disk clone. installed in pc and at first power on it stops at no boot device...
This is what I disliked about the "Sony hard drive partitioning plan" - they don't give you all of the C partition and then you run out of space. Out of frustration, I formatted the entire hard drive so that no remnants of Sony was in it and installed a fresh copy of the operating system, used the product key from the original operating system, sticker (label) affixed on the case to active Windows again. I got the entire C partition all to myself! Since you cloned that hard drive, you still have the "Sony hard drive partitioning plan".
Dec 30, 2010 | Sony VAIO Digital Studio PCV-RZ24G PC...
Need to know how to upgrade a hard drive from a 8 gig to 80 gig
I am typing this on a Dell 4600 RIght now. You need to look up how to set the jumpers on the internal hard disk ( 8GB) to SLAVE MODE, and set the 80GB to Master.
Remove the 8GB from the metal bracket, and put the 80GB in its place. Put the 8GB beside it. Plug the 80GB into the end of the IDE cable, and the 8GB into the middle. When you boot, you can hit F2 to go into the bios, and change the boot order from HD0 to HD1 and you can boot from your 8GB.
Now, If you want to boot from the 80GB, ( which I would ) you need an operating system.
Get your Disk labeled Reinstallation CD, Microsoft Windows XP Home Edition, Including Service Pack 1, and boot from it. Then format the 80GB, and install the OS There.. You will need your WIndows XP Home Key. ( you can either get it off the case or use Magic Jelly Bean Key finder to get it off your 8GB. Get the key and write it down. ITS IMPORTANT ).
Then you can change your boot order in BIOS, back to HD0, and boot from your fresh copy of XP Home.
If your interested in having a close to seamless experence as possible, you might want to invest in a copy of Partition Magic Pro. It can copy both the restore partition, ( the first 600MB of your 8gb disk ) and the primary partition of the 8gb, and resize the 8gbs primary partion on the 80gb to 80gb. ( YEA! ).
If you have *any* *any* lack of understanding please clarify
Oct 01, 2009 | Dell Dimension 4600 PC Desktop
Replace the factory hard drive in my sisters Dimension 2100 with a eagate Barracuda 7200.10 Hard Drive - 80GB - 7200rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal. I go to run the Windows Xp CD that...
If the system is older,you may be limited by the BIOS. Many old systems do not recognize a partition with Windows.
Have you run fdisk for the format and partition setup?
Did you check the BIOS at startup? Make sure it recognizes the drive in BIOS and sees the partition. Hit F2 on bootup.
If it sees the drive, use a boot disk and run fdisk. Check the parameters and then run the install again.
Aug 18, 2009 | Dell Celeron M, 1.3 GHz (SL86L) Processor...
Upgrading hdd in hp ze4805us to 250GB WD -- Won't Boot
since your bios says theirs a limit to HDD capacity you may want to try making the 250GB disk into 2 smaller partitions. Then extract your OS image to the first partition.
Apr 16, 2009 | HP Pavilion Ze4805us Notebook
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Hard Disk Partition
you have make Bookable floppy to boot & restart when it show 3 types you can choose without cd rom sopport and type fdisk then u can edit from there.
Sep 21, 2008 | Maxtor Hard Drive
try using a partitioning utility like gparted, pmagic, partition magic etc. this will tell you whether your drive is full, partitioned, how much is used and if the partition takes up the full disk. also, try doing scandisk on it to see if there are errors and to get the errors fixed
May 25, 2008 | Computers & Internet
Boot problem
you have to set the master boot record to bootable.. I dont know how you would do this in windows, maybe you can do it with grub or something.. or maybe just search google for restoring master boot record(mbr).
Televison & Video Logo
91 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
