Question about Zebra LP 2844 Thermal Printer
Reinstalled zebra printer on different computer
After adding the drivers from the original disk.... I try to print test page and get
q408
Q812, 20
OD
D10
S4
ZT
JF
N
GW80, 141,29,470
  • 258 Answers
The printer is set to the wrong mode, do a reset on the printer to default settings, or factory reset, but you could have installed the wrong drivers for your printer from the install disk you got if it was working before you installed them, so uninstall and let your computer automatically install standard drivers for it or if you need to install the exact drivers, do just that from the install disk, make sure you know exactly the model of your printer
Posted on Jun 29, 2009
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Why won't my printer print a test page
try to uninstall and reinstall the software and if that does not work see for error message and if not printer is bad.
Oct 25, 2009 | Zebra LP 2844 Thermal Printer
Pages come out but not printing
Recommendation: Go the the manufacture's website and download the device driver and reinstall the printer. Make sure that the printer is on and connected to the computer before you run the download. Also when finishing installing the printer, print a test page.
Sep 30, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
P430i - Ribbon Broken / Out of Ribbon error
ribbon cut again and again after put 2 or 3 cards pls give instruction how to solve the problem.
Mar 03, 2009 | Zebra P330i Thermal Card Printer
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
Doesn't pront the whole picture
Will it print it's own status page? or a page of just basic text? Are you printing a picture? You may need more than 30+ Megabytes of free disk space for the print job to spool.
0) Verify your Hard Disk has enough free space.
1) turn printer off for 1-2 min. Turn back on and try again.
2) Reboot the computer and try again.
3) Shutdown all other programs and try printing again.
4) Try printing from another program. (ie. while reading this, click print ;-) )
5) unplug printer from wall and computer; remove driver; reinstall from original disk.
6) Try printer on a different computer
If this does not help; take two aspirin and call back !
Jan 10, 2008 | HP DeskJet 940c InkJet Printer
Zebra LP 2844 Thermal Printer Logo
306 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
