Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
1/2 is regular electric. The other 2 burners are
1/2 is regular electric. The other 2 burners are induction. The induction part doesn't get hot very quickly. It is an old model. The electric current to our apartment is not as high as it should be. Could this be the problem, or is it the stovetop itself? Thank you.
  • 138 Answers
Just change big fuses in box.
Posted on Jun 29, 2009
How do I fix an Electrolux induction range element that is not at full power?
Thank you for your post, friend!
I see that you are having difficulty with your induction range element on your Electrolux range. From the information you have provided it is taking longer for items to heat up on that burner. You may need to have that burner replaced and I would recommend having a professional technician come out to perform any repairs. This is not a simple DIY job it may require a possible disassembly of your range. I hope this information has been helpful. -Matt
Feb 18, 2015 | Electrolux EW30IS65JS - 30"Electric...
Gaggenau 200 Series?
If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
I can only offer basic suggestions of which you already probably know.
These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
Jan 02, 2014 | Gaggenau Cooktops
Maytag Range won't heat up oven or cook top
you have melted internal wiring, probably some mice ate it. call an electrician and DO NOT USE IT!! turn off at the wall/fusebox
Nov 20, 2013 | Maytag MER8770WS 30" Freestanding Electric...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Water boiled over on the Right rear induction side. Stove shut off. Now the Right rear burner doesn't work and flashes and "F" when I set any temperature. Stove thinks I have the wrong type of...
Generally there is a number after the F. It sounds like some liquid got into the electrical, sometimes if you wait about a week for it to dry it will work. If not, you would need to call a service tech
always unplug electricity before attempting to repair on any electrical appliance
Sep 14, 2017 | Electrolux 30" Built-In Electric Cooktop -...
I have an induction cooktop model EW36CC55GS and when I plug it, it shows an error E95, I look for a error code chart but there is none. Can someone know what is this error?
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
Aug 13, 2010 | Electrolux 37 in. Designer Series...
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Wolf electric induction stovetop
I had that happen once and it went off after a day. I'd suggest maybe turning off the breaker and wait a few minutes and turn it back on. But here's my problem for you. I got the 30" model in March, 2008. The problem I've had is that the induction units cool down and start cycling when I'm cooking something like bacon, or pork chops etc., ie. where you're trying to brown something or sear. They cycle up and down every couple of minutes, so its really annoying. They work fine if I'm boiling water for pasta or sauces, etc. Have you experienced this. I've been working with the dealer and the company and they say its a "software" problem, but they've haven't taken them off the market. I use All-Clad stainless steel pans so that's not the issue. Thanks for your comments.
Aug 16, 2008 | LG 30" Built-In Electric Induction Cooktop...
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
139 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
