Question about Texas Instruments TI-83 Plus Calculator
The buttons in the last row will not work.
All of a sudden all the buttons in the last right row will not work. If I press any of the (clear through enter) it gives a subtraction sign. I changed the batteries and cleared the RAM but nothing works.
  • Texas Instru... Master
  • 8,068 Answers
It looks like a hardware problem. You must have it repaired.
Good luck.
Posted on Sep 14, 2009
We dont have a manual and we dont know how to change the channel or set the time
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
Aug 22, 2011 | GPX KL858S 8.1 in. Under Cabinet TV
Do you have the Nintendo Tetris game watch instructions?
Right red button toggles between game and watch. In game press right blue button to begin game with sound, left to begin game without sound. Use blue buttons for left, right, rotate(up) and drop(down). Clear twenty rows to go to next level. High score is recorded. In time mode press and hold left red button to set, Use left to set hours and right blue to set minutes. Press left red to set.
Oct 06, 2010 | Watches
How do I find out what my extension number is on my meridian phone
Press feature *0(button inquiry) then your intercom button(last or second to last on the right row of 5 buttons). It will display your intercom number and name if programmed.
Aug 14, 2010 | NorStar Meridian M7310 Phone
Up,right and clear button not working when opened
i have the same problem on my phone and i was unable to fix it but i could get the clear, up, and left buttons to work by sliding the screen down a tiny bit until the buttons on the screen light up (they are not lit up when the phone is slid out). you won't be able to push the top row of keys, but by sliding the phone slightly down you should be able to use the clear, up, and left keys
Jul 23, 2010 | Samsung Sway SCH-U650 Cell Phone
I have a Sharp AR250 Copier that got the H5-01 after I had a paper jam 5 times in a row. I found a solution on here to clear the code by pressing P*C*14(start) but the problem I am having now is finding...
Hello.
Yes .. that machine doesn't have a " * ", so press the Interrupt button instead of the " * ".
So it was P interrupt C interrupt 14 start, press execute - on screen. Then, turn the machine OFF and back ON and code should be cleared.
The icon for the interrupt button looks like two horizontal lines with an arrow pointing from right to left between the lines.
Hope this helps.
Apr 05, 2010 | Sharp AL-1641CS Laser Digital Copier
How do I change the time
Change the time with the original remote on the DVD player. Enter the menu, chose time or system, select the time, whatever is coloured or blinking in the time menu will be changed. Use the up/down buttons or enter the number you want (depends on the model). Don't forget to press enter or go back out of the menu before you shut off the DVD. If I have a model #, I can probably be more precise. Follow the guide that came with the model for best results.
Mar 19, 2010 | JVC Televison & Video
Buttons on far right row of ti-84 plus clear the screen
It seems like a harware problem. I think you shoul have the calculator repaired.
Hope it helps.
Aug 16, 2009 | Texas Instruments TI-83 Plus Calculator
The last row of icons on my iphone won;t work. Help....
The last row of icons which is the bottom row with Phone iPod etc?
It sounds as though your digitizer is bad, the iphone digitizer is delicate and seems often goes bad.
does your unlock screen work?
the bottom off the screen handles the unlock and bottom icons.
if your unlock switch works then you may just have a software problem going on.
reboot your phone by pressing and holding the power and home buttons until the apple appears.
when it reboots see if it works properly, if not you may have a bad digitizer.
is your iphone a 2G or a 3G?
Jun 03, 2009 | Apple iPhone Smartphone
Can't finalize cd on the Electron Brand 9290 Nostalgia CD Burner
In stop mode, press "finalize" (last button in the top row of buttons), then press "play" (center button in the lower row of buttons).
Jan 02, 2009 | Electro Brand Nostalgic Stereo CD Music...
Display not centered
there are 6 buttons at the buttom of the monitor.
option 1). press the auto adjust.
option 2). from the right to left: "power","LED","Manu/enter",">"," <" ,"auto adjust"
to adjust the screen:
press manu-button, use <> button to navigate to the 3rd button on the top row.
(4way arrow). press manu again. that is going to get you into the submanu.again use the <> to navigate to H. Postion button.use the <> to mve the screen to the desire postion.
press manu again and select the right button on the button row (exit) and press manu.
Nov 06, 2008 | Envision EN-7220 17" Flat Panel LCD...
Texas Instruments TI-83 Plus Calculator Logo
111 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
