Question about Canon i9100 InkJet Photo Printer
I have an 8-year old Canon i9100, and have just installed my third brand new Print Head. It worked fine for one month, then the black started fading and then just stopped printing. All the other colors are fine. I've cleaned and deep cleaned about 1000 times, soaked the head overnight, and put drops of ammonia on the purge block for overnight soaking, and reset the eprom. I'm told it's not the print head, as there is no print head error. Any ideas?
  • LoNicot
    LoNicot Jun 29, 2009
    Does anyone have the part number for the purge assembly? For a Canon i9100?
    President:
  • 2,306 Answers
It is probably a bad purge assembly, when it doesn't clean or prime the printhead properly you have the problems you are describing. There are 2 sections in the purge assembly, one cleans color and the other cleans the black. Sounds like the black pump is worn out. The part runs around $30.00
Posted on Jun 29, 2009
  • Craig Gillette
    Craig Gillette Jun 30, 2009
    The purge assembly is Part # QG4-0204-000
My printer prints blank pages when I want to print files from my computer, but works fine without a computer
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an Epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging yourprint head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 24, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Canon i9100: colors printing incorrectly
I've had the Canon i9100 since 2003 and have excellent photo printing results. In 2009 it started playing up and I'd gt some banding. More recently, black didn't want to print. It was as though the black ink in the print head got dry some days.
April 2010 - The colours started printing strange and I bought a brand new print head and installed it. Only takes a minute. Still had an issue with photo printing. Black and white was excellent but colours weren't true.
Found advice online to try cleaning the print head to print head carrier electrical contacts by rubbing them with a rubber eraser.
I did that and now I'm getting perfect colour photo prints again.
I had been thinking about buying a new A3+ printer but this is old printer is now working as good as new.
Nov 16, 2009 | Canon i9100 InkJet Photo Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer prints color, but not black even with new cartridge
First thing to do is a head clean then do a test print. Do you see any of the black lines?
If not, don't do a deep clean as this uses up too much ink. Remove the ink cartridges and then remove the print head unit.
Run the print head under a hot tap for a few minutes until all the run off is clear. Take it outside if you can and shake it dry vigourously. You can use paper towel if you like but try not to wipe across the nozzles. Make sue the contacts are all dry and refit it to the printer. reinstall the ink cartridges and print a few test pages - the first couple may well be wasted but then it should start to print properly.
Is the black still missing? If it is do another head clean and another test print. Any improvement? If you start to see some black do some more head clean routines and it may well come back to normal. If on the other hand you see no trace of black at all, it could be that the print head is worn out and needs replacing.
This printer is now of an age where the print head may well be failing. Mine had to be replaced last year as one of the colours stopped printing.
The head is not exactly cheap - but it's cheaper than buying a new A3 printer.
Sep 10, 2009 | Canon i9100 InkJet Photo Printer
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Photo printing problems
Try to manually clean the printer head. Take a cotton cloth and dab a little bit of alcohol (like whiskey) and then clean the printer head & the cartridges with it. Do remember it is a delicate process and if you messup, you might damage the printer/cartridges. So be careful & lemme know the result.
Aug 06, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Canon i9100 InkJet Photo Printer Logo
348 people viewed this question
old marine
old marine
