Question about Weslo Exercise & Fitness
Stop when you step on - Weslo Exercise & Fitness
    Problem Solver:
  • 16 Answers
Does the motor stop completely or just the walk belt stops. If you can see the front roller to see if it is turning inside the walk belt this would be of great help for diagnosing the problem. Let me know and we will go from there. Also if you can remove the hood or motor cover, whatever you want to call it that will also be helpfull for the diagnosis.
Good luck.
Posted on Jun 29, 2009
How to reset canon E600 printer
To reset Canon printer we have to follow certain steps, they are:-
STEP 1: First check that your printer is turned on.
STEP 2: Now press the power button, this will turn off your printer.
STEP 3: Once turned off, press on the STOP button for two seconds.
STEP 4: While holding on to the STOP button, press the power button at the same time for two seconds and release the STOP button. keep in mind that you have to press both buttons simultaneously.
STEP 5: After letting go of the STOP button you have to still press the power button, press the STOP button five times.
STEP 6: After pressing the STOP button for five times, release the power button.
I expect that this will resolve your problem.
Jun 27, 2017 | Canon Office Equipment & Supplies
2004 chevy impala brake light isses switch has been replaced and so have fuses and bulbs still no lights
Do you know how to test using a DVOM - digital volt ohm meter ? Is there B+ voltage going into the brake light switch ? An coming out when the brake pedal is pressed ? What fuse's ? There is only one fuse for the brake lights !
The BRAKE SW fuse in the RH I/P fuse block supplies battery positive voltage to the normally-open stop lamp switch. When you press the brake pedal the switch contacts close and battery positive voltage is supplied to the left and right stop lamp assemblies and to the center high mounted stop lamp (CHMSL). The left and right stop lamp along with the CHMSL are grounded at G302.
Do you know about the right insturment panel fuse box ?
Stop Lamps Inoperative
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Did you perform the Lighting System Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Press the brake pedal.
Do all of the stop lamps illuminate?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are all the stop lamps inoperative?
YES - Go to Step 4
NO - Go to Step 7
Inspect the BRK SW fuse.
Is the fuse open?
YES - Go to Step 14
NO - Go to Step 5
5
Disconnect the stop lamp switch.
Using a test lamp connected to ground, probe the battery supply voltage circuit of the stop lamp switch connector.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Install a fused jumper between the battery supply voltage circuit and the stop lamp switch signal circuit of the stop lamp switch connector.
Do the stop lamps illuminate?
YES - Go to Step 12
NO - Go to Step 17
7
Determine if the center high mounted stop lamp is inoperative or the stop/turn lamps are inoperative.
Are the stop/turn lamps inoperative?
YES - Go to Step 8
NO - Go to Step 9
8
Do the turn lamps operate normally?
YES - Go to Step 17
NO - Go to Turn Signal Lamps and/or Indicators Inoperative
9
Disconnect the center high mounted stop lamp.
Using a test lamp connected to ground, probe the stop lamp switch signal circuit of the center high mounted stop lamp at the harness connector.
YES - Go to Step 10
NO - Go to Step 15
10
Using a test lamp, probe between the stop lamp switch signal circuit and the ground circuit of the center high mounted stop lamp with a test lamp.
Go to Step 11
Go to Step 16
11
Inspect for poor connections at the harness connector of the center high mounted stop lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 19
12
Inspect for poor connections at the harness connector of the stop lamp switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 18
13
Repair a open or high resistance in the battery supply voltage circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 20
14
Repair a short to ground in one of the following circuits:
• The battery supply voltage circuit of the stop lamp switch
• The stop lamp switch signal circuit of the stop lamp switch
Go to Step 20
15
Repair a open or high resistance in the stop lamp switch signal circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
16
Repair an open or high resistance in the ground circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
17
Repair an open or high resistance in the stop lamp switch signal circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
18
Verify the stop lamp switch adjustment. Refer to Stop Lamp Switch Adjustment . If OK, replace the stop lamp switch. Refer to Stop Lamp Switch Replacement .
Go to Step 20
19
Replace the center high mounted stop lamps. Refer to High Mount Stop Lamp Replacement .
Go to Step 20
20
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jun 23, 2017 | Cars & Trucks
03 cadilliac deville brake lights won't come on
test brake light switch --underdash on bracket attached to brake pedal
Jun 06, 2017 | Cars & Trucks
2007 Silverado Classic 4x4 crew cab after parking the vehicle the headlights turn off but not the brake and back up lights How do I repair this problem?
DTC B2550
When the body control module (BCM) receives a signal requesting to illuminate the backup lamps, battery voltage is sent directly from the BCM through the backup lamp supply voltage circuit to the backup lamps.
Voltage for the backup lamp supply voltage circuit as well as the courtesy lamp supply voltage circuit is from the left instrument panel fuse block TBC 2B 15-amp fuse directly through the BCM to these circuits.
Brake lights or do you mean tail lights ?
Stop Lamps Always On
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle
Depress the brake pedal.
Does the system operate normally?
YES - Go to Testing for Electrical Intermittents
No - Go to Step 3
Do the brake lamps go out?
YES - Go to Step 6
No - Go to Step 4
Remove the CHMSL fuse.
Yes - Go to Step 7
NO - Go to Step 5
5
Remove the STOP fuse.
YES - Go to Step 8
NO - Go to Step 9
6
Inspect for poor connections at the harness connector of the switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs.
YES - Go to Step 11
NO - Go to Step 10
7
Repair the short to voltage in the CHMSL supply voltage circuit. Refer to Wiring Repairs.
YES - Go to Step 11
8
Repair the short to voltage in the stop lamp switch signal circuit. Refer to Wiring Repairs.
Go to Step 11
9
Repair the short to voltage in the stop lamp supply voltage circuit. Refer to Wiring Repairs.
Go to Step 11
10
Replace the stop lamp switch. Refer to Stop Lamp Switch Replacement.
Did you complete the replacement?
Go to Step 11
11
System OK
Go to Step 3
Dec 09, 2016 | Chevrolet Silverado Cars & Trucks
Stannah 300 instruction
There is a set stop at step one keep holding the joystick on up & it should pass this step after a short delay, the first step stop is for storage whilst if it's behind a door so you can open it fully, also for hoovering the floor under the seat area at the bottom/start point etc, but definitely clean the track of any dust or debris & wd40 lightly it after & clean the seat/track sensors at the top & the first step & bottom of the track stops, as there is 3 track stop spots, if these are obstructed it will prevent the stairlift from completing its full ride. Hope this helps....
Jan 13, 2018 | Health & Beauty
Canon printer reset mp258
Reset Canon MP258 Printer
Step 1 Turn off your printer. Step 2 Press and hold the STOP RESET button then press the POWER button Step 3 Release STOP RESET while holding the POWER button, then press the STOP RESET 2 times Step 4 Release both buttons simultaneously Step 5 The printer control L C D panel will show the 0 value and your computer will detect NEW DEVICE Step 6 Turn off your printer Step 7 It's done. Your printer is ready to use again.
Sep 14, 2012 | Canon PIXMA MP250 Inkjet Multifunction...
Camera launcher.exe does not work anymore
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
Nov 20, 2011 | Canon Digital Rebel XT / EOS 350D Body...
My canon printer MP258 SHOWN ERROR 5200...what can i do to solve this problem?
Step 1 : The printer is off and plug the power cord.
Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button
Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
Step 4 : Release both buttons simultaneously
Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0)
Step 6 : Computer will detect NEW DEVICE, Ignore it...
Step 7 : Press the power button, then the printer will turn off
Step 8 : Press the power button again, then the printer will be ready to use
Let me know if this has helped or if I can assist you further,
Thanks
Mar 31, 2011 | Office Equipment & Supplies
My printer canon pixma mp258 have error....P08 appear on the LED
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge.
Step to resolv this error
Step 1 : Turn Off Printer
Step 2 : Remove Cartridge
Step 3 : Refilling the cartridge
Step 4 : Reinstall the cartridge
Step 5 : Turn The printer ON
If it still does not work you can use the following methods
How To Reset MP 258 error 5200
Nov 16, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
We have a 4 in 1 printer by hewlett packard and we do not know how to stop the endless printing of an earlier print out. what do we need to do?????
  1. Click "Start"
  2. Step 2 Click "Run"
  3. Step 3 Type in "services.msc"
  4. Step 4 Click OK
  5. Step 5 Find Print Spooler in the list of services
  6. Step 6 Click "Stop"
  7. Step 7 Once the service has stopped, restart it by clicking on "Start"
thank you,
Lee
Mar 26, 2010 | HP PSC 2410 All-In-One InkJet Printer
Exercise & Fitness Logo
132 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
