Question about Canon PIXMA MP830 All-In-One InkJet Printer
Carrier won't move to center so cartridges can be inserted.
Cartridges were removed to clean printer. Cartridge carrier is now positioned to the far right and will not return to center area. Printer shows error code 6500.
  • jhaustin881 Jun 29, 2009
    What the heck is the data cable I am to re-attach? Where do I find it? I see three thin ribbon type cable s(?)and a wide white cabe(?) that all seem to be under tension.
  • 583 Answers
White wide cable is called data cable.also check if motor connections inside the printer are well connected as if its not connected properly or loose than it wont be able to move the carriage
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 29, 2009
    President:
  • 1,383 Answers
Just reattch data cable to cartrdge carrier.
Also refix ink cartirdges into it.
Put some oil in ink cartrdge carier bus .
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Why will my ink cartridge not move to the center so i can tak e it out.
Sep 10, 2011 | Lexmark X2470 All-In-One InkJet Printer
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
Print cartridge would not move to loading position to allow installation of new cartridge
Aug 17, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
116 people viewed this question
old marine
old marine
