Question about Bazooka MBTA8200 Marine BT Series 200-watt powered 8" bass tube Car Speaker
Vrx Bass Tube Built in amplifier
I have connected everything properly but i think it si something wrong with amplifier, becouse can get any sound although the power led is on and the speaker separately is working...
And do anyone know which is the remote wire in car audio for Peugeot 306 1994?
Thank you
    Problem Solver:
  • 15 Answers
Hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Posted on Nov 14, 2007
I want to build an amp that will deliver a bass drum sound for the stomp box I built.
As a 40 year guitarist and repair technician I had to laugh at this until I thought about my younger days of starting out. What I see here is that you made a momentary trigger out of a stomp box that apparently had problems, that you think you can build an electronic bass drum to play it with. Is this correct? See, the amp only gives a bass drum sound ONLY if a bass drum sound goes through it. Amps only provide audio power to the input signal. Where to get you bass drum sound is what you need to find. I believe you are thinking of a sample. A sample is an actual recorded sound of a bass drum that you could actually trigger by stepping on that button. You could find this on most cheaper casio, yamaha, emerson, radioshack, keyboards or drumpads or any of those amateur toys. Most of them allow a trigger pedal to be plugged into it and operational. Now, after you find something with a bass drum sample that you can trigger with your pedal, that device should allow you to plug it into an amp to amplify it. I hope I didn't confuse you much and had a close perspective of what you tried to describe. Please let me know if I can help further.
Mar 10, 2014 | Music
My 21" Plano TV , replace the Picture Tube becous
It sounds to me like it has the wrong scan coils fitted to the replacement tube and there is no fix for that. You will need to fit the correct tube or have the old tube re built.
Dec 28, 2010 | Samsung Televison & Video
I have a 1800 watt amp but the red light is on but it dose sound like the bass works but not it its prime
the red light is for power in protect mode it should be orange and it will not emmit sound if you think you should have better sounding bass or more bass you can try to play with the gains on the amp or possibly if you have the negative or positive hooked up wrong from a speaker to the amp this will cause the bass to be lower and somewhat distorted double check your positive and negative wires from the speaker to the amp and make sure they are correct
Feb 28, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Gain conrol problems
relatively simple 2 leg pot. fix.
Under $50 to repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Jl Audio 500/1 Car Audio Amplifier
TECHNICS SUPER BASS, DOUBLE BASS AND TRIPLE AMPLIFIER
Have you checked all circuit boards for good solder connections.
Also if the boards had been wet from anything, you might clean the boards and resolder all connections specially in the power supply and audio section.
Let me know.
Jan 26, 2009 | Technics SUV500 2-Channel Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
P3001
Tighten very good the ground wire to your amp, then clean the metal where the ground attaches to the car chassis. Then tighten the ever lovin' bejesus out of the chassis ground. Yeah, I'm from the South :)
Good Luck!
barneyluc
Sep 28, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
ZX1500.1 Major Problem
If the subs are pushed to their limits straight out and remain there as long as the amp is on, the amplifier probably has shorted output transistors. If the speakers are moving in and out like they would be on a bass note, there may be something wrong with the shield ground of the head unit.
Dec 13, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Bazooka MBTA8200 Marine BT Series 200-watt powered 8" bass tube Car Speaker Logo
473 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
rd2xpld
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
