Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Power light is off...everything is plugged in and the signal from the modem was stopping there...if I hook the modem straight to the computer everything works.
    Problem Solver:
  • 18 Answers
Modem is faulty, no doubt about it.
Posted on Jun 29, 2009
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
I plug my router into my modem and it just doesn't want to work with me. Everything was working fine, and then last night my connection gradually got worse until I lost the Internet. I plugged my computer...
There must be a small reset button on your router. Hold it down for 30 seconds. Release it. wait for one minute. Now unplug the power and plug it back in. Wait for 1 minute.
Once you reset the router, it will come back to factory default settings.
You will need to reconfigure the router form the start according to your Internet service provider.
Click here for step by step instructions
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys modem with a netgear wireless router. The other night my internet just stopped working and now it is though the modem is not transmitting a signal. I have connected 2 different computers...
the ds light is for downstream which is your digital signal simply put...... if the light is not going solid to denote being :"online" there maybe signal related issues. rain will mess up the cable signals as the service is exposed to elements etc.....here is a trick i do with a modem that doesnt want to lock on to good signal.....reboot the damn thing...........give it a minute or two.. if the online light doesnt sync up solid....unscrew the cable connector on the back of the modem while it is powered up and wait 15 seconds////then screw it back on (needs to be hand tight, its like a water hose, if its loose you get signal loss) and give it 10 minutes......if it still doesnt lock up and go solid indicating online then call your cable company, you should not get charged for their service not working correctly..........it then would be something only a tech could fix. but if it does lock up and go solid ....hook up your router , power it up and give it a minute to sense the modem, restart the computer and you should be good to go...
Jan 21, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
Netgear software, picks up wireless network then loses connection moments later
Netgear generally functions well. You may simply need to adjust the location of the router. Check the signal strength when you do have a signal. You may be losing a signal intermittently because the signal is weak. If your signal is "good" or better and the signal is lost without apparent reason, there could be a malfunction with the router itself. Check the router when the signal is lost and ensure the power light is on and the connection light is on.
If your signal is weak and you lose it intermittently, adjust the location of the router
If your signal is strong and you lose it intermittently, you may be experiencing a connection problem at the source or the power may be cutting out at the modem. The more likely answer is the source signal interruption. It is rare for a power supply to go bad in those.
Check the source connection INTO the router.
You can also reset the router. You'll want to unplug everything. Unplug the power supply from the wall AND from the modem and leave it unplugged for at least 2 minutes. There may also be a very small recessed reset button (the kind that you need to use the end of a paperclip to press). Press and hold that for 10-30 seconds to reset while it's still plugged in.
When you plug everything back in, plug the power in first (to the wall and modem), then connect the source cable. Wait until you have a signal confirmation light, then try to connect with your computer.
Last but not least, the connection problem could be with your computer. Try pluging directly into the source if possible and see how that works. Then try just moving close to the wireless modem and see how the signal strength is and if you lose the signal the same way. If there is a switch on your computer to turn on the wireless feature, make sure it's all the way on. Sometimes these are kind of stuck between 'on' and 'off' and that can cause problems.
I hope one of these suggestions helps you!
Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
Belkin N router reads everything but the computer.
If your router was working before, and suddenly stopped working, then you probably need to reset it.
Unplug the router from power, also unplug all network cables from it.
Wait about 30 seconds.
Plug power back in, followed by network cables.
Wait some more seconds while the router restarts.
Only the Power light and the Status light should be solid.
All others in use must be blinking, which means they are in use.
Try connecting to the internet with cable first, then try wireless.
It should work.
Please don't forget to rate if answer is helpful
Jun 22, 2009 | Acer Aspire 5050-3242 Notebook
I have a linksys wrt54g router. Lost power the other day and now router does not work with cable modem. All the settings are the same on the router, power, wlan, and internet lights are on. Tried to reset...
Check to make sure that your route has DHCP turned on.  Save your settings and turn everything off.  Power on you modem and wait at least one minute, if your modem has a link light, it should come on and stay solid once it connect with your ISP.  Then turn on your router and wait another minute for it to sync with your cable modem.  Finally, turn on your computer.  Remember that everytime that you plug something new into your cable modem, you have to reset your power.
May 03, 2009 | Linksys Wireless-G WRT54G Router
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Has my router gone bad?
If no power lights come on... it looks bad, but try another power adapter on the router before tossing it... could be that.
Jan 09, 2009 | D-Link AirPlus DI-614+ Wireless Router
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Jeff
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Receive, send, and activity lights are all blinking but online light is off
Power Cycle the modem if the 4 lights do not go solid you would want to contact your cable provider to ensure signal is being received properly to modem.
Jul 27, 2008 | Arris SURFboard SB4200 Modem
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
77 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
