Question about Kenmore Washing Machines
Sounds like rocks while spinning
Sounds like rocks while in the spin cycle could it be change in the drain? It is not consistant and happens only when spinning
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Washer sounds like it has rocks in it during spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Whirlpool GHW9100L Front Load Washer
Error code OF 2 When this error code appears it happens during the spin cycle. I manually switch to the Drain/Spin cycle and change the spin speed to medium and press start. This fixes the problem each...
It sounds like you may have a motor control board issue. It acts like the motors brain and tells it what to do and when. part number 8182706. Also the closet error code i could find is a f/02 which means long drain, which could indicate a bad pump or draining cycle, alos knows as the spin cycle This should definetly be diagnosed by a technician. hope this helps
Thanks
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fixed the clutch. Now has a rock crushing sound when spin starts
Hello askeng,
I would try to fault isolate the noise area by removing the front cover (watch the belt) and start a Spin Only cycle with no clothes in the wash basket. It’s a 10 minute cycle so let the wash basket spin up to full RPM. Do you hear the rock crushing sound? If it sounds like the problem area is the clutch pulley area terminate the cycle with the Off Key. Check for any trace of a water or transmission oil in that area.
If that’s not the cycle causing the excessive noise I would next do a quick wash with no clothes in the wash basket and see if the grinding/rock crushing sound is coming from the tumblers in wash cycle, maybe some change under the tumblers.
When you cleaned/re-lubed the one-way roller clutch bearings how did they look? Did the Spinner Shaft Coupler (I show it in this post) rotate freely CW in both the upper bearing (if used) and the lower bearing? Let me know your findings and if you have additional questions. Rich
Jun 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Ultimate Care II LSQ9549L does not always spin
This unit has a neutral drain transmission. When it first goes to spin it will drain without spinning to ease load on motor. It will then pause motor and when it restarts it then spins.
You probably have a bad timer that is not pausing the motor. Monitor washer from the start of spin cycle to end to see if it pauses then starts again. If not, replace timer.
Sep 25, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
20 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
