Question about Hardware & Accessories
Malibu light timer. I have 2 black and 2 red timer sets or pegs that you insert for time. Which is which ?
    President:
  • 1,723 Answers
Red is 'on'& black is 'off'
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 30, 2009
Red is on, black is off how can I get additional pegs to replace lost ones?
Posted on Dec 09, 2009
Where can i find malibu red/black timer pegs for outdoor lighting?
Posted on Aug 08, 2010
2 Suggested Answers
  • 56 Answers
SOURCE: I have Malibu outdoor
Red is on and black is off Insert the peg at the time in which you want it to come on or off. The time of day is for your current time.
Posted on Oct 02, 2010
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
How do you set lighting to turn on and off throughout the day?
You posted under Malibu power pack.
If you have analog dial that rotates as time passes, then setting on-off times is accomplished by using black and red tripper.
Usually the timer comes with 2 red ON trippers and 2 black OFF trippers.
Place trippers on outer edge of dial and then set timer according to instruction manual.
If you need more trippers, they can be ordered
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Open following link if you need instruction manuals or troubleshoot steps for setting up power pack.
Add a comment with exact model number if you want more detailed instructions, and add your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 05, 2011 | Malibu ML200RT - Low Voltage Power Pack...
How do I set the timer for the malibupower pack
set the dial to the corect time by turning the dial. remove the clips by pulling straight out. reinsert clips on the desired times for on and off red on black off
May 24, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
Black Peg on timer
We just used to use a sliver of bamboo, just make a piece and sand it down, bit by bit, until it is a Tight fit in the hole you want about 5mm to protrude, through the bottom, that is what "Trips" the "Contacts" inside. So anything similar will work too. Just remember whatever you use, has to protrude a little bit inside the face of the Dial. & be strong enough, not to break when pushing the Contact.
Mar 28, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
Upvote the help.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Lights won't automatically turn on BUT will automatically go off
Are you using the red peg for 'on' and black for 'off'?
Jun 17, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Hardware & Accessories Logo
2,130 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
