Question about Kenmore Vacuums
The Dirt Sensor lights will not go out. It doesn't matter if I am vacuuming carpet or tile floor, the dirt sensors are all lite up. I can't locate my owners manual.
  • 120 Answers
Your machine could be clogged, check the tools for suction. If its a bag less model you might need to clean or replace your filters.
Posted on Jun 29, 2009
Panasonic Dirt Sensor vacuum repair
Dirt Sensors are sensitive. It doesn't take much to set them off. Try pulling back on the handle to raise the brushroll a few inches off the floor so you know it's not detecting particles of soil. If the light doesn't turn green it may have dirt on the sensors and need to be cleaned.
Nov 25, 2017 | Panasonic Vacuums
Hoover - Red Light Dirt Sensor
check to make sure the settings didn't get inadvertently switched to the hi position, move the switch back and forth from high to reg a few times, then leave it on reg.
remove and hand wash the primary filter and secondary filter, dry throughly and replace them in the vacuum.
if none of this works, you will need to have the vacuum serviced, or if it is still working, just don't pay attention to the dirt-finder. the dirt sensor on your vacuum is located in the suction tube and is generally not accessible enough to clean without taking the vacuum apart.
hope this helps,
trin
Nov 20, 2007 | Vacuums
Red "DIRTY" light is on most of time, even after going over and over what should be clean carpets. Head is lifted, getting good suction. Got a solution?
The sensor that detects the dirt can get dirty causing the light to stay on. Hold the vacuum up in the air or position the vacuum in a way to observe the light when the vacuum is running but the nozzle assembly is not on the floor so it cannot be picking up any dirt. If the light will not go off it's likely the sensor needs cleaned.
Mar 09, 2017 | Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Do; you use #1 or #4 for hardwood and tile floors
Use the 1 setting. The brushes spin but it is a soft brush and will not scratch. Make sure the thin rubber squeegee behind the brush is still in good shape. That prevent dirt from being kicked out behind the vac. Hope this Helps
May 07, 2011 | Windsor SR12 Sensor Bagged Upright Vacuum
Uh70015 dirt sensor stays on green. Goes on red for about 5 seconds then green. Can clearly see the floor is dirty and it is picking up stuff.
ahh the good ol electronics on vacuums selling the product again...
not to worry, your feature is working properly, your vacuum is working fine too.
Imagine if you will making a circle with your pointer finger and your thumb. Now put a string or thread across in a straight line there. The string would be the size of the beam of light that the sensor uses. Your finger and thumb are about the size of the tube that the dirt and dust is passing by. Unless the dirt passes and cuts through the beam of light, then it will register. otherwise if it passes around the beam of light, the sensor thinks your carpet is clean.
The opposite sometimes will happen too where it will stay constant red. That means that the sensor is completely covered in dirt and will not register anymore.
Hope this helps.
Mark
Nov 11, 2010 | Hoover UH70015 Bagless Upright Cyclonic...
Can you clean carpet with dirt devil floor keeper
Refer to http://www.dirtdevil.com/products/details.aspx?id=MCE5500 for the manual.
From the looks of the manual it's just for flat floor surfaces (vinyl, lino, tiles, etc).
May 25, 2010 | Dirt Devil CE5500 Floor Keeper Upright...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
Problem with embedded dirt finder
Take the hose off at the back of the vac, should just turn then pull oull, look down inside the tube that the hose was connected to, there is a sensor there and if it is coated over with dirt, then it can't work, Clean it off and the try it, if it still stays on, then you have a bad sensor, and if this is less then a year old, you have a one year warranty on this. Take it to a warranty shop and take proof of purchase with you.
Oct 24, 2007 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
150 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
