Question about Brother HL 2140 Laser Printer
My usb connector is broken where to find the board
My usb connector on my HL-2140 is broken. where to find the board to replace it?
    President:
  • 2,306 Answers
The board is number LV0050001, around $40.00, from Brother.
Posted on Jun 29, 2009
How can I replace the corona wire in the drum of brother HL 2140 printer, I've seen it broken, I'd disassemble the assembly and two terminal lugs w/ broken corona wire dislocated to its position.
Hi, I have the same printer as you. My background is in the development, design and manufacturing of printers. while i didn't have the opportunity of designing the toner system, I do know that doing anything with the corna wire requires that you never touch the wire with your bare hands.Replace the corna wire requires special tools to set the tightness keeping clean in the process. Unfortunately by the time you spend to replace the wire, it would be easier to buy a replacement drum. there are some reasonable cost rebuilt drums sub systems. look on ebay to find them.
Jan 31, 2015 | Brother HL 2140 Laser Printer
My printer HP ( HL-2140 laser ) print out a black sheet?
This will be the Corona Wire on the drum has broken. Replace the Corona Wire if you are technically minded or replace the drum unit if you are not.
Jan 10, 2015 | Brother HL 2140 Laser Printer
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
May 04, 2011 | Brother HL 2140 Laser Printer
Brother hl 2140 printer not responding to computer
Check your cable connections. This is a common problem with USB connected printers.
Feb 18, 2011 | Brother HL 2140 Laser Printer
If im going to print my document the selection for printer HL - 2140 series 2 was lost and replace by the printer generic how can I reset the printer bask to HL - 2140 inorder to activate?
Brother HL - 2140 Drivers
Visit the above link from Brother Official Support. Select the Operating System and download the drivers. After in stalling the drivers, go to the Control Pannel - Printers, and set HL-2140 as default printer.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 24, 2011 | Office Equipment & Supplies
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
Printer not printing documents HL-2140 model
when the toner light is on this means the toner cartridge is empty and ned to be replaced. After its replaced it will start working normally again.
Jun 02, 2010 | Brother HL 2140 Laser Printer
Can a Brother HL-2140 printer be connected to a laptop?
I have a MacBook and the Brother HL-2140, they work great with no problems. Should have the drivers for Windows and Mac on the same disk. I am connected by USB.
Jan 25, 2010 | Quicksilver , Mac ATI RADEON 7000 64MB...
Brother HL-2140 printing black pages.
Hi Nacardi,
Could be bad toner (toner sitting on shelf for too long). Or the drum could have been over exposed. The drum is light sensitive.
S88
Dec 14, 2008 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
190 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
