Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
I cannot run internet with my router
I am RUNNING wINDOWS VISTA, but my N1 MIMO router can see my Internet connection or I cannot go to the unternet.
  • nanette7fl Dec 29, 2007
    i have a belkin n wireless model FD8233 and I cannot get it to recognize the modem
    Problem Solver:
  • 16 Answers
Clone the MAC address of your computer into the router.
Best to do is following these steps.
1. wire your computer directly to your modem. Do you have connection with the internet. (If no the problem is not the router but your modem or vista settings.
2. Disconnect your computer from the router. Do not switch off the powersupply!
3. Connect the utp cable in the router and connect a new cable between the computer and the router.
4. write in the explorer addressbar 192.168.2.1 (you should get the belkin setup page; see the manual)
5. look for MAC address ore MAC adress cloning. I'm not familiair with your type but I think you should look under the paragrapg WAN connection.
6. press clone MAC address and wait.
Try out if your having a internet connection bij going to your homepage.
Regards,
Pascal
Posted on Jan 23, 2008
  • 57 Answers
Downgrade your vista to windows XP Pro or XP home..
Posted on Nov 14, 2007
Laptop running windows vista won't connect to router in Europe.
You need to call the internet provider. They more than likely have a different protocol to set up in order for your internet to work.
Jun 25, 2012 | HP Computers & Internet
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
Modem light blinking and no internet in the wireless router. but when i run a cable from my modem to my computer, internet works....but when i rund the cable from the modem to the belkin wireless...
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Apr 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Cannot connect to internet
hopefully you have'nt give the pc the same ip address as the other as it won't connect.
You will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your wireless network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Open up internet explorer>tools>internet options>connections tab and ensure that never dial a connection is ticked or the option greyed out, close I.E. then open up again, click refresh and it should connect.
Sep 28, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin router F5D9230-4 connection issues
First thing to do here is to reset the router, Press and hold the reset button for 15 seconds while the power is ON then after that unplug/replug the power for 5 seconds then run again the setup CD and if the router is still working after the reset it should be configure by the setup CD, if not I will advice you to contact Belkin tech support so they can further check if the router is bad already and if its still under warranty they can replace it....
Hope that helps..........
Sep 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G USB Network adapter 802 11g password
give me the model and brand of your router. The key is in the configuration page of your router. email me at unit_4105@yahoo.com
Jul 02, 2008 | Computers & Internet
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
172 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
