Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
Sub Zero 611F "vacuum condenser" warning persists, unit not 100%
For a week or so, the unit has been fine in the freezer (bttm area) but not cooling below 45 in the refrigator. Vacuuming the condenser has not helped. The warning light keeps coming on. Having read some posts, I looked for and found an area of condensation on the rear left wall of the refrigerator, halfway down. Not enough water to pool. Not even dripping down the wall. Yet, that is. Is there no other possibility than a hole in the evaporator as one answer suggests in an old post? Is there something more simple that one can try before calling for service, Is this necessarily a sealed system component issue, as the person suggested?
  • Sub-Zero Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sub Zero freezer keeps running
What is the model number of your unit?
Oct 21, 2012 | Refrigerators
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2011 | Refrigerators
The freezer on my side by side works just fine but the refrigator side is not cooling very well
Hi
Check the back wall or floor of the freezer section for frost. Check the freezer or the evaporator fan to see if it is running. Check the condenser coils (under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both doors wide open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please check this links to get a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#coolingispoor
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Frigidaire Side by Side Refrigerator 23...
Freezer is fine, but refrigerator is not cooling at all.
check the damper vent door between the refrige and freezer behind a plastic grille and make sure theres cold air coming in from the freezer,sometimes they freeze shut from condensation and can't open to cool the refrige
Jan 01, 2011 | GE Profile PFSF5NJW
I have amana DRS2662W- I had turned the defrost timer but now the freezer and the fridge are not cold enough- there is no ice forming, I can hear the compressor and fan behind but not cooling.
You should never need to advance your defrost timer. If your defrost is not working properly, the coil in the freezer compartment will ice up, blocking all airflow. All of your cooling is done there, even the refrig area, so you will never get down below appx. 40-45 degrees.
my first suggestion is to look at the back panel in your freezer for frost/ice build-up. If yes, unplug the unit, open the freezer compartment and let it thaw overnight. If it starts cooling properly, you have a defrost problem. It may be a bad timer(often), thermostat(less frequent), or bad defrost heater(even less).
Nov 15, 2010 | Amana DRS2663B Side by Side Refrigerator
Refrig/bottom freezer not cooling, fan running, lights running, controls working fine, every 5 minutes a humming, then a clicking....cleaned condensor fans and cleaned condensor coils by vacuuming My...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 30, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Hi, we have a GE refrigator. We are just back from vacation and the freezer and cold area are not working. The lights work and power seems ok.It was purchased April 2000. The model number is: TPX24PRBJWW....
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | GE Refrigerators
Refrigerators Logo
612 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
