Question about Vizio Gallevia GV42LF 42 in. LCD Television
I have a vizio gv42lh tv just had main board replaced. watched for 2 days now turned off and will not turn back on even after unplugging. Same problem as before new board installed.
  • 4,234 Answers
If the work was done by a service shop, you should have received a 90 day guarantee of the work. Please call the service center and indicate that the "repair" was not successful. They should resolve the problem without additional cost to you.
Dan
Posted on Jun 29, 2009
I have a Vizio E50-C1 Model #LTCWSKAR Power supply # (X)ADTVE2420AD4 Main Board #GXFCB02K009050X
You need to find out which board the led driver resides on. The main board sends a signal to the power supply board to turn on the LED's Look on the power supply board for swollen capacitors. They all have to have flat tops. If any are bulged, they have to be replaced www.shopjimmy.com. TV Parts Universal TV Stands DLP Chips ShopJimmy These guys can tell you which board you need.
Jul 28, 2017 | Vizio Televison & Video
My vizio tv 600I b3 won't turn back on right away after being unplugged. The only way it comes back on is by leaving it unplugged for a hour to two days. The time it needs to be unplugged is increasin
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 25, 2015 | Vizio Televison & Video
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
I have a vizio tv and it wont turn on it showed the vizio logo and now it wont turn on and its been like this for 2 days
The main board will need replacement. Its very common issue where the set will freeze at the vizio kogo then eventually it wont turn the logo from orange to white so it can power up. Replacing the main board should solve the issue. You can get the replacement main board from www.tvcircuitboards.com
Jan 03, 2013 | Vizio L32 32 in. LCD HDTV
My vizio flat screen tv turned off on me and it wont come back on. At first i was watching it then all of a sudden the screen went black and all i could hear was the sound. Now when i try to turn it on or...
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 06, 2017 | Vizio P4 46 in. HD-Ready Plasma Television
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging...
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Aug 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A won't turn on
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
May 22, 2008 | Vizio L32 32 in. LCD HDTV
L37 tv turns off on own and then will not turn back on
I have same problem and i put in a new power supply and this did not solve problem. I will be changing out main board next and post results.
Jan 31, 2008 | Vizio L37 Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
168 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
