Question about Canon PIXMA MP780 All-In-One InkJet Printer
Error code #361
This code is shown when I try to print. I removed and re installed
the software, it worked for a while but is now saying code error again.
There no paper jam - what can I do?
  • 112 Answers
Unistall it and reinstall it with the correct driver. the best is to download the new driver from canon website.
Posted on Jun 29, 2009
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
Error code 49.FF01 can't turn on or off
A firmware error occurred ( This error is usually caused by a bad formatter board)
SOLUTION
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
Feb 22, 2011 | HP LaserJet 4250tn Printer
On power up of HP5550 dtn an error is shown; error code 49.4401
I'll list what the book says, but if you haven't got the basic knowledge
you are going to have to call a printer tech. Good luck
1.
memory.
2.
Turn the printer off and then
back on.
3.
printing a different file. If the
message appears only with a
4.
PC.
5.
6.
firmware DIMM in slot J1.)
7.
the printer.
8.
9.
device.
causes the error.
computer.
the firmware DIMM.
Dec 06, 2010 | HP LaserJet 5550 Printer
Error code 0051930 49.bb28 Printer prints old jobs even when it says no jobs stored. I have turn off the printer, unpluged the printer and it is slow or much later or not at all print the job requsted.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor-quality parallel cables, poor-connections, or home-grown programs.
On rare occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message displays only with a certain software program or print job, contact the software vendor for assistance.
5. If the message persists with different software programs and print jobs, disconnect all of the cables to the printer that connect it to the network or computer.
6. Turn the printer off.
7. Remove all memory DIMMs or third party DIMMs from the printer. (Do not remove the firmware DIMM.)
8. Remove all EIO (JetDirect Cards) devices from the printer.
*Remember to protect from ESD
9. Turn the printer on.
10. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and on again as you install each device.
Apr 26, 2010 | HP LaserJet 4700 Printer
All data has "disappeared" from my 300G usb 2.0 drive.
you can use a software called g parted , you have to make a dos bootable , and then mount volumes to make the drive ready.
gparted will help you... try the trial version .if you dont susceed let me know.
Feb 06, 2009 | Iomega Silver USB 2.0 Hard Drive
I wish to print but it will not print so I decided to re install the software, however, HP 4100 all in one will not uninsall and the error says the uninstaller is not working.
try reinstalling OS if possible.
try other methods, like Add/Remove Programs... from control panel to remove old softwares.
If you are an expert try removing the same from your file system / registry...
Dec 29, 2008 | HP OfficeJet 4255 All-In-One InkJet...
How can i resolve the error code 88780078 shown by winamp
Try going into the device manager and removing the sound driver. Hopefully you have the sound card driver. Then reboot the Pc if the system installs the driver software and you hear noise your good. If that doesn't install it from your cd. If it works try uninstalling the program that caused the problem.
Nov 29, 2008 | Audio Players & Recorders
Error 361
I've the same problem. Error 361 in the scan mode with MP 780. The offical Canon support told me it's a mechanical problem and I've to bring it to the service. But scaning works and printing isn't a problem too. So I don't believe its a mechanical Problems. Looks more like a Firmeware-bug.
May 21, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
238 people viewed this question
old marine
old marine
