Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
How do i restor factory settings
I have no remote control and there is an error message saying the operation with control panel is prohibited.
3 Suggested Answers
SOURCE:
SOURCE: can't use my remote control
you have to do it manually on the t.v. using the menu, channel.volume, and input buttons on the side of the T.V.
Posted on Dec 31, 2010
spr1949
  • 1182 Answers
SOURCE: how can I do a rest on this tv? I can't use the remote. I put new batteries in and that didn't help. And now I can't use the keys on the side because it says operation with the control
Please follow guidelines in operation manual, step by step.
Posted on Aug 06, 2012
How do I factory reset a Sharp Aquos LC32D44U?
You must have its remote control to make it to factory reset. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you have the remote control, just enter its service mode; surf through and select the 'Factory Reset' option, and press OK.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sorry to say that nothing more can be done without its remote control, other than contact the authorized service center for help.
Aug 01, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Cod resoftare nokia 7100s2
Restore to factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only -0 to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
Apr 17, 2014 | Philips Televison & Video
The operation with remote control is prohibited
What is the exact Brand name and Model number to your TV?
Aug 15, 2012 | Televison & Video
How do i unlock my PC-P2HT control panel thank you.
It took a while but here it is:
6) Anti-Tamper setting (locking the Remote Control) This setting will prohibit the use of the operation mode, temperature adjustment, air-flow and auto-louver settings*.
a) In normal operation mode, press and hold the "r UP and Down buttons for more than 3 seconds"
b) "OPER. LOCK" will appear on the remote control display.
Repeat to unlock.
Thanks for choosing FixYa,
Kelly
Aug 04, 2011 | Heating & Cooling
If I take out the battery on my skylink sc-100 does it reset it back to factory settings.
I guess the question is about the control panel SC-001.
If power is totally removed (disconnecting DC jack and removing battery) from the control panel, user settings will be restored to factory default. These include all passwords and zone settings. Master PIN will be reset to "000" and secondary PINs will be deleted. Home, Away, and Night sequence default zone setting can be found in the manual.
However, all programmed sensors and remote controls will remain intact. This means that all programmed sensors would still trigger the control panel if activated. And programmed remotes would still operate the control panel. To remove installed sensors or remotes, simply disconnecting power will not work. User must follow instructions in the manual to remove sensors or remotes from a zone.
Feb 19, 2011 | Skylink Group Skylink Sc-100 Security...
Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
Oct 29, 2008 | Sharp RRMCG1687PESA Remote Control
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
157 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
