Question about Toro Lawn Mower With Toro Power Tools
I need to remove the flywheel on my Toro 20016 sothat I can drill out and replace the clamp screw for the oil filler tube. What kind of puller should I look for to accomplish this task? Thanks sdidier
4 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Toro 20016 engine surges up and down - then stalls
You have carburetor problems. Chances are the diaphragm needs to be changed and the carb. needs a good cleaning. If you need tips on carb. cleaning, let me know.
Jim
Posted on May 29, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
SOURCE: grinding gears and no traction for toro front
The transmissions gear is bad need to replace
Posted on Sep 01, 2010
A mouse chewed the spark plug wire and so now I need to replace the ignition coil. What do I need to do to get to the coil?
remove top cover a couple screws then remove pull cord cover then remove flywheel may need puller then access to coil but while in there check keyway on flywheel if not square replace could be causing no spark
Apr 14, 2018 | Toro Garden
How to replace fuel tank filler tube?
Brother John, you've removed as much as you can for access to the filler. Remove the hose clamps/bands that secure the fill tube and vent tube and then remove the screws around the gas cap that secure the fill tube to the body. With the gas cap off, go below and pull the hose and filler neck down and work the hoses lose with a pair of channel lock pliers and sticking a screwdriver between the metal tube and hose to break the seal. Put on the new filler neck and stick it back up in the body and put the screws back in. THEN put the hose clamps back up and tighten them, put the gas cap back on and your done.
Nov 30, 2014 | 2000 GMC Jimmy
How do ireplace a flywheel key on a toro z153
Remove cowling from engine.
Remove flywheel ( may need puller)
Remove and Replace key, if damaged.
Reinstall flywheel.
Reinstall cowling.
May 12, 2014 | Toro Lawn Mower With Toro Power Tools
How to remove gas tank from toro 20016
Your Toro model 20016 came equipped with a Tecumseh engine. To remove the fuel tank, follow these steps:
1. Remove the fuel hose from the tank and drain any remaining gasoline into a container. If the gasoline is still good (fresh, clear) then save and reuse it. If the gas is not good (contaminated with water, old) then dispose of the fuel properly.
2.. Remove the upper red plastic engine cover. There are 4 screws with 1/4" hex heads holding the cover on. You will have to temporarily remove the oil cap to allow clearance.
3. The tank is held on with 2 screws and 2 clips. The screws will be obvious and on top. (some models the screws are the same as the cover screws). If necessary, remove the 2 screws. Tilt the tank away from the engine and pull upward. This will release the clips and allow the tank to be removed.
4. Reinstall in the reverse order.
Oct 27, 2010 | Toro Garden
Do I need a special flywheel puller for a 2007 Tecumseh 6.5 hp engine. I need to remove flywheei to reconnecr dround wire.
Hi Pat--
You don't always need a puller, but your chances of breaking things are greatly reduced if you do have one. If you're going to try to remove that flywheel without a puller, here's what usually gets me good results:
1) Remove cowls and panels as necessary until the flywheel is exposed.
2) Find 2 or 3 wooden stakes that will fit securely beneath the the flywheel. Square pieces about twelve inches long are best.
3) With the wood blocks underneath the flywheel, GENTLY pry up and down between the flywheel and the block evenly all the way around the wheel. You may have to tap the top of the flywheel with a rubber mallet.
Occassionally, some penetrating oil sprayed onto the flywheel's keyway will help make the separation. The real trick to doing this is to pry beneath the flywheel evenly all the way around it. Be patient and take your time. If in doubt, get any gear or wheel puller and, after tightening to GENTLE pressure, give the flywheel a few taps at its center with a rubber mallet. It should pop off.
Hope this helps.
Oct 06, 2010 | Toro Garden
My 3 year old 22 inch walk behind mower will not start, I replaced the spark plug, there is no spark when I pull the hand start
Replace the flywheel key by removing the rewind housing, the flywheel nut and then remove the flywheel by using a small engine universal puller (cheap) and install a new key.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Toro sprewing oil
The filler spout tube may have pulled out of its seat push and twist to reinsert it down. if the oil is over filled you must drain some out to return it to its correct oil level, if it did pull out of its seat the small bolt holding the filler tube in place may have loosened up and fallen off it must be replaced if this happened.
Oct 03, 2009 | Toro Lawn Mower With Toro Power Tools
Mower wont start
You will need to replace an aluminum "key" in the flywheel. Whenever you hit something, the key is designed to shear so you don't break something major.
Sep 02, 2009 | Toro Lawn Mower With Toro Power Tools
Bolt comes loose and rip cord is yanked from hand
  1. block off the blade and driver assembly with a 2x4 to keep it from moving
  2. remove the flywheel nut (regular hand force should be sufficient)
  3. tap the 3 holes on the flywheel (if they aren't already threaded) using 1/4inch 20national tap set
  4. remove the flywheel using a flywheel puller -- a harmonic balancer puller which matches the tecumseh bolt pattern on the flywheel also works using 3 1/4inch thread (20national, 2inch long) bolts with washers
  5. NOTE: (if the blade was removed/reinstalled, tighten the blade to manufacturer's spec of 60lbs) before installing the new flywheel key
  6. remove the sheared flywheel key
  7. clean up the flywheel (wipe off all the dirt and grease)
  8. install the new flywheel key (part 611004 for toro 20016)
  9. install the flywheel (pull the bail brake handle to get the ball-brake inside the flywheel)
  10. tighten the flywheel nut to manufacturer's spec of 37.5lbs
  11. prime the gas bulb, give it a pull and mow away
Aug 24, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
130 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
