2007 Chevrolet HHR Special Edition Logo
A
Anonymous Posted on Jul 15, 2014
Intallation instructions for Fuel module for 2007 HHR
The colors on the wires leading to the new fuel level sensor are purple and blue.. the old one is purple & blue.. need to know which wires goes where.
5 Related Answers
Anonymous
  • 1263 Answers
  • Posted on Sep 01, 2008
SOURCE: 2007 HHR Wiring diagram
is there spark? is their fuel? also if it was wrecked chances are that the fuel cut-off switch was triggered. i have not ever worked on one so i don't exactly know where it is but i would check behind the fabric/hard plastic right rear/left rear wheel hosing and see if you can hit the reset switch. another suggestion is go to napa or oreillys and get a repair manual for it it has diagrams and schematics in it and it cost about 20 bucks.....good luck please rate this.....thanks
tharris396
  • 24 Answers
  • Posted on Dec 01, 2008
SOURCE: astro van wont start
Did you check for spark? Is it getting gas at the fuel rail? If there is no spark then it could possibly be the crank position sensor, ignition module or coils but the coils do not all go bad at the same time.
Anonymous
  • 206 Answers
  • Posted on Mar 02, 2009
SOURCE: 2007 HHR Poor Fuel Mileage
My 2006 HHR gets 30 to 35 miles to the gallon
Anonymous
  • 253 Answers
  • Posted on Apr 30, 2009
SOURCE: 2001 Chevrolet Impala 3.8 fuel pump wiring diagram
The wires should be grey, orange and black, purple, and a black wire. The purple goes to purple, grey to gray. The orange and black goes to the small black wire on your car harness and the black goes to the bigger black.
Anonymous
  • 198 Answers
  • Posted on Sep 23, 2009
SOURCE: 1994 chevy suburban, no fuel coming from fuel
Put an injector noid light at the injector plug terminals to see if your getting a signal from the PCM(computer).If not try to find a computer from the same vehicle that works and swap it into yours to check.A PCM swap will take about 15minutes.
I need wiring guide for 2000 Cadillac Deville fuel pump
Here's a wiring guide for the fuel pump on a 2000 Cadillac Deville: 1. Remove the fuel tank and access the fuel pump module. 2. Disconnect the electrical connector from the top of the fuel pump module. 3. Locate the wiring harness that runs from the fuel pump module to the car's electrical system. 4. Cut the wires on the old fuel pump module connector, leaving enough wire to splice the new connector onto. 5. Connect the black wire from the new fuel pump module connector to the black wire in the car's wiring harness. 6. Connect the purple wire from the new fuel pump module connector to the purple wire in the car's wiring harness. 7. Connect the gray wire from the new fuel pump module connector to the gray wire in the car's wiring harness. 8. Connect the black/white wire from the new fuel pump module connector to the black/white wire in the car's wiring harness. 9. Connect the new fuel pump module electrical connector to the car's wiring harness connector. 10. Reinstall the fuel tank. Note that it is important to follow the wiring guide carefully to ensure proper installation and avoid damaging the fuel pump or electrical system. If you are unsure about any step of the process, it is recommended to seek assistance from a professional mechanic or refer to the vehicle's service manual.
3helpful
3answers
Need color code on new connector
Just did my fuel pump on the 2001 isuzu rodeo. Well here is what you need to do about the different wire colors. First disconnect your negative battery. Drop the fuel tank and replace pump. Remember to have a splice kit in hand. Ok now here is how you connect the different colored wires. Black goes with black. Gray goes with black and orange wire. Purple goes wit blue and yellow. And the last wires goes together. I hope this helps.
P2175,po463,poo32
Hi there:
DTC P0032 - Oxygen (A/F) Sensor Heater Control Circuit High (Bank 1 Sensor 1)
A P0032 DTC (diagnostic trouble code) refers to the O2 sensor (oxygen sensor) located on Bank 1 in front of the catalytic converter. There is also an oxygen sensor behind the converter which is Sensor #2.
This O2 sensor #1 may also be refered to as an air/fuel ratio sensor since on some vehicles it is. The sensor detects the amount of oxygen in the exhaust gas compared to the outside air and then vehicle's computer adjusts the air/fuel ratio going into the engine. The sensor is less effective when the exhaust gas temperature is low, so it includes a heater which is activated to help get better readings from the O2 sensor. Essentially this P0032 code means that the resistance of the heater circuit is higher than normal. In some cases, that resistance level must be higher than 10 A to trigger the DTC code.
Note, this code is very similar in nature to P0031, P0051, and P0052
Most likely you'll not notice any symptoms other than the MIL (malfunction indicator lamp, a.k.a. the check engine light) will illuminate.
A P0032 DTC trouble code may be caused by one or more of the following:
A short in the heater circuit in the sensor
A failed O2 sensor heater
Wiring/connectors broken/frayed leading to sensor and/or relay
Failed PCM/ECM
Possible Solutions:
To fix a P0032 DTC code, you'll need to do a proper diagnosis. To do that, you'll want to inspect the wiring and connectors leading to the sensor. Also if equipped with a heater relay and fuse, you'll want to check those as well. Use a digital volt ohm meter to:
check for 12 volts at the heater circuit feed (hint: unplug the sensor and check at the wiring connector to do this measurement)
check the ground circuit for continuity
measure the resistance of the heater circuit (done on the sensor itself)
measure the resistance and voltage of the wiring
Refer to a service manual for the correct specifications (volts, ohms) for your vehicle. On some Toyota vehicles this code is triggered when the resistance of the heater circuit is above 10 A.
With that said, a common fix for this DTC is to replace the air/fuel (O2 oxygen) sensor #2 on bank 1.
Please keep in mind that OEM (original equipment) replacement sensors are recommended (from the dealer). Aftermarket sensors can be less reliable and of poorer quality (not always, but more often). There's also a chance that replacement parts for the P0032 code may also fall under a federal emissions warranty (check with your dealer to see if it's covered).
DTC P0463 - Fuel Level Sensor Circuit High Input
The fuel level sensor (sender) is located in the fuel tank usually integral to the fuel pump module. Usually they cannot be replaced without replacing the fuel pump module, though there are exceptions. There is a float attached to an arm that travels along a resistor which is grounded to the tank, frame or has a dedicated ground circuit. Voltage is supplied to the sender and the ground path changes according to fuel level. How much voltage depends on the system but 5 volts isn't uncommon.
As the fuel level changes, the float moves the arm and changes the resistance to ground which varies the voltage signal. This signal may travel to a fuel pump computer module or directly to the instrument cluster module. Depending on the system, the fuel pump computer module may only monitor the resistance to ground and then relay the fuel level information to the instrument panel. If the fuel level signal to the fuel pump module (or instrument cluster module or PCM (powertrain control module)) goes above 5 volts for a specific amount of time, then the module that is monitoring the fuel level circuit will record this fault code.
Symptoms of a P0463 DTC may include:
Mil (Malfunction indicator lamp) illumination
Fuel level gauge may fluctuate abnormally or read empty or full
Fuel light may illuminate and sound alarm
Potential causes of a P0463 code include:
The signal circuit to the fuel sender is open or shorted to B+ (Battery voltage)
The ground circuit is open, or ground path may have high resistance due to rust or missing ground ******** fuel tank
Damage to the fuel tank could cause problem in fuel level circuit
There's an open in the fuel lever sensor's resistor to ground
Possibly faulty instrument cluster
Less likely is the possibility that the PCM, BCM, or Fuel pump computer module has failed
Possible Solutions: Fuel pump senders normally last the life of the fuel pump. So if you have this code present, do a visual inspection of the fuel tank and wiring harness. Look for damage to the tank indicating impact that may have damaged the fuel pump or sender. Look for missing ground strap or a rusty ground where the fuel tank is grounded to the frame. Check for damage to the wiring harness connector. Repair as needed. Find out what kind of system you have and verify that voltage to the fuel level sensor is present at the fuel pump wiring harness. If not, repair the open or short in the wiring.
Doing a voltage drop test on the ground circuit can determine if there is a high resistance path in the ground circuit. You can perform this by using a voltmeter and connecting one lead to the battery ground post and the other to the fuel level sensor ground at the tank. Turn the key on (preferably the engine should be running). Ideally it should be 100 millivolts or less (.1 volts). Anything close to 1 volt indicates a current problem or a developing problem. Repair/clean the fuel level sensor ground as needed. It's not impossible that the instrument cluster has failed internally or on the printed circuit board (if applicable). These are very difficult for the layman to test. But if you have access to a wiring diagram you may be able to remove the cluster and see the damaged circuit if it's located on the printed circuit board, but otherwise you'll need a scan tool that will communicate with the instrument cluster.
A simple way to test the fuel level circuit is to provide a good ground to the fuel level sensor at the fuel tank connector. With the key on the fuel gauge should go to one extreme or the other. Removing the ground path completely should cause the gauge to do the opposite. If the gauge responds, you know the wiring that supplies voltage and ground to the fuel level sensor is good and that the instrument cluster is likely okay. The likely suspect would be the fuel level sensor itself. The fuel tank may need removal to gain access to the fuel pump module in the tank. A PCM or BCM (Body control module) failure isn't impossible but highly unlikely. Don't suspect this first.
DTC P2175 - Throttle Actuator Sys - Low Airflow Detected
Chec HERE (page 350) the PDF information about this test and solution code (P2174 and P2175).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
3answers
Honda passport fuel harness
If it is the correct fuel pump - where it unplugged, it should just plug in where the old one did.
Need check engine codes po463 what does this mean
Possible Solutions:
Also, DTC P0462 - Fuel Level Sensor Circuit Low Input, same test to diagnosys.
DTC P0700 are transmission codes. Apparently something went wrong and the computer detected a difference in the position of the shift linkage and what gear the vehicle was in. You should be able to drive the vehicle during this period of time. The only thing you should be aware of is to make sure you don't feel any transmission slipage, otherwise you are fine until your appointment.
DTC P02610 - Control Module Long Term Memory Performance
This code is often set because the battery went dead and you tried to start it. There is a calibration update to correct this and it will not require a new ECM. See you dealer for the calibration update.
What is the purple wire on the fuel pump connector on a 2007 G6 Pontiac for
hello
the purple wire is the 5 volt reference wire for the fuel level sensor
How to replace feul sensor on 1998 saturn
Hello: You have to lower the fuel tank to replace the fuel level sensor. To do this you need to disconnect all fuel lines and that also includes the fill hose and vent hose. Also disconnect the electrical wires. A lock ring holds the fuel pump module in place, remove it (counterclockwise) When removing the fuel pump module assembly you have to turn it some and pull up easy, becareful that you don't pull to hard and make the module come apart (both the module and fuel level sensor are expensive) You will see how the electrical connection works when you remove the old one. The Senor mounts on the side of the fuel level module. You have to release a plastic clip to remove the old one. You have to re-use the float assembly.
Harness colors don't match new colors to chng fuel pump connector
i know what you are talking about, last time i looked at the wires on the pigtail i cut off and i determined which color went to each pin location. then transfered my findings to the new pigtail.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
