Question about Digi PortServer II Terminal Server
Portserver ii keeps losing connectivity with the data switch requiring it to be disconnected and re-connected to the switch to re-establish connection. I have switched cables but connect still is lost randomly. What's up?
    Scholar:
  • 162 Answers
Sounds like its a naming problem, if two or more devices on your network have the same ip address it will cause intermitent connectivity. if this is not the case then you should contact manufacturer to see if there are any problems which they are aware of involving this problem.
Posted on Jun 29, 2009
How do I reconnect the WD harddrive to the Bell PVR with out losing what I have already transfer
It is very simple, just re-connect the device and restart the process for remaining data and simultaneously check if you have lost any data or not. If you have lost your data then you have to show your machine to an expert for Recovering Data from Hard Drive.visit us http://www.maidenheaddatarecovery.co.uk
Oct 24, 2014 | Western Digital WD Passport 250GB Portable...
I have a digi portserver 2 16 port. When i connect the power, its not getting switch onn. Any idea how to fix my problem.
I am ASSUMING you mean power on, right. Is this an AC powered unit or DC? If it's DC make sure when you connect your volt meter from the - to + terminals that you are getting a +48vdc. If you are installing this in a telecom facility chances are the power plant is -48vdc which would mean you will need to connect the ground side to the positive terminal and the source side to the negative terminal.
If you are using AC verify again with a volt meter that you have 110/120vac and that the plug is properly grounded. This is easily done from the female end of the power cord. If that is fine there should be a fuse on the unit check that.
Let me know how it goes.
Nov 26, 2012 | Digi Portserver Ts 8 Mei Terminal Server -...
I keep losing my internet connection though my modem stays connected
go to internet connections delete connections then search and establish new connection
Sep 03, 2012 | Arris...
My modem ADSL data light keeps flashing and sometimes does not appear affecting my ability to acces the Internet. I usually have to re-boot my computer and this seems to solve the problem for a time. It is...
I usually have to re-boot my computer and this seems to solve the problem for a time. It is very inconsistant and anoying.Thank youM. Davis
ADSL DATA light flashes says there is internet activity (Internet status: Connected)...
ADSL DATA when off says there is no internet activity (Internet status: Not Connected)...
This occurs when there is a lot of noise in your telephone line...
It is adviced to do a line test in this case to find the amount of noise in your line...
If there is a lot of noise your modem will lose the internet connectivity and will try to re-establish the connection with ISP...
In this case the ADSL DATA light switches between OFF and ON...
One more thing...
ADSL SYNC light should be steady...
If it is blinking is says there is no syncronisation between your modem and ISP...
Dec 08, 2010 | Belkin Computers & Internet
I keep losing internet connection every few minutes. the light will turn red and then reboot itself. i tried all of the different channels and it does not help. what is wrong
If the light turns red then it says, there is a lot of noise on your telephone (dsl) line..
If there is a lot of noise, then the dsl will lose the connection and it will try to establish a connection again...
at this point you will lose your internet connectivity...
So i advice you to contact your ISP and ask them to change the telephone line from the junction box...
or ask them to check the amount of Noise in your DSL line...
Signal to Noise ratio (SNR) value on your DSL modem should be more than 40db for greater connectivity...
If it goes below 30db, you will face frequent disconnection and very slow internet...
Nov 26, 2010 | 2wire (1000-000057-000) Modem
Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to battle.net.
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Mar 12, 2009 | Belkin Computers & Internet
GULF- FORTEC 5600 II NOT WORKING
Have the same problem since one week now 'network established but disconnected !. I have fortec lifetime II receiver. I have ver 6.1.0 and trying to download 6.1.29 using com port from PC, no success. keep getting error ' downloading not requested'. it's a mess !
Aug 18, 2008 | Fortec Star Lifetime ULTRA
HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
Jun 20, 2008 | HTC TyTN II Smartphone
Blackjack II internet stops working....
Hello again dogbyte!
Fantastic! I'm thrilled to here the first fix went well!
Here's the deal on your most recent question...(Please excuse the long post - I'm intimately connected to this particular issue, so I figured I'd try to share some of the background on it.) Are you using GoodLink version 5.0.x by chance?
Our team has actually submitted bug reports to both GoodLink and AT&T on this issue. The BlackJack II has a connection setting called "AT&T IMS" (supposedly there to offer additional features on the AT&T network sometime soon.) Unfortunately, when GoodLink 5.0 is provisioned on a BlackJack II with this particular GPRS connection setting, internet problems are basically guaranteed.
The BlackJack II will successfully connect to the internet to download, install, and synchronize GoodLink. The first time the device disconnects from data services (i.e. - roams out of data coverage, the device is powered off, the device hits critical battery, etc.), data will not reconnect.
You've got two options:
I. Delete the "AT&T IMS" GPRS Connection Setting
1) Navigate to Start > Settings > More... > Connections > GPRS
2) Use the multi-directional pad to highlight the AT&T IMS connection.
3) Click Menu > Delete
4) Press Yes to confirm the delete.
5) GoodLink and Pocket IE should be able to connect to data services again in 5-10 minutes or less.
Note 1: Solution I needs to be performed again if the device is hard reset. If your user(s) need to hard reset the device upon occasion, you may want to make the instructions above readily available to the user, OR consider option II to prevent confusion (if option II is available).
Note 2: Changing the Access Point Name on this connection from "ims.cingular" to "wap.cingular" can also solve the problem, but it's not always consistent.
I. Provision the BlackJack II with GoodLink 4.9.3.x.
This last stable release for GoodLink 4.9 seems operate without the same data issues. Although Good 4.9.3.x doesn't offer some of the more robust features of Good 5.0 (such the ability to send email attachments from the device or RSS feeds), we've been deploying Good 4.9.3 to BlackJack II users since we discovered this issue a little over two weeks ago, and it's definitely made a postive difference.
Another Potentially Related Issue
You may also notice surprisingly frequent "403 Forbidden" messages in Pocket Internet Explorer on AT&T devices (including the BlackJack II).
All Internet Explorer traffic from an AT&T device goes through AT&T's proxy. AT&T's proxy apparently includes a rule that disconnects a user if they haven't used the web for a specific period of time (I've heard 2 hours, but that may vary). Unfortunately, AT&T and Microsoft haven't figured out a way to simply open that Pocket IE connection back up... at least not easily.
If you're seeing "403 Forbidden" errors, you'll want to do one of the following to close and reopen the data connection:
I. Reboot the phone
(closes and reopens all of the connections)
II. Manually disconnect cellular data
1) Click the Power/Quick List button on the top of the BlackJack II. The "Quick List" should appear
2) Select Wireless Manager
3) Click Menu > Disconnect cellular data
(You should notice the "MEdia Net" indicator under "Phone" change to "On")
4) Click Done to return to the Homescreen.
5) Open Internet Explorer again and navigate to the desired page.
Note: Although the "403" error doesn't necessarilly interfere with GoodLink connectivity, manually disconnecting cellular data will. If you don't open IE an actively open a data connection to reach the web, you'll probably want to open GoodLink and do a quick manual Send/Receive, just to make sure that it re-establishes its connection.
Sorry for the book! I hope one or both of these help.
Have a great weekend,
The MoDev Kid
Apr 18, 2008 | Samsung BlackJack II Smartphone
Digi PortServer II Terminal Server Logo
87 people viewed this question
Top Digi Computers & Internet Experts
Alun Cox
Don Hart
Chris Larocque
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
