Question about Amana DLE330RAW Electric Dryer
My dryer doesnt dry. I believe it is the heating element. only cold air is coming out
  • 138 Answers
To replace coil, unplug and take off the back. Might have to remove heat shroud to get at coil. Remove and replace. You might have bad contacts on relay switch so play with them first and plug it back in to try it. If it doesn't work then do first step
Posted on Jun 29, 2009
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
I have a frigidaire FEX831CS0 that doesnt get hot while drying. Just blows cold air. Im assuming heating element...
Before you reinstall the part, have your ducts and air vents cleaned so it won't burn out again. It only costs around $150.00 but will make a huge difference in your air quality as well as heating and dryer issues.
Mar 05, 2014 | Frigidaire FEX831CS Top Load Stacked...
My Bosch electric dryer wta3510uc heats but doesnt get hot like other dryers. why is that? it takes over an hour to dry or even more and it use to seem much hotter. clothes are still cool and damp after 40...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Bosch Axxis WTA 3510 Electric Dryer
WED5321SQ0 dryer doesn't heat or shut off once it's running
well if ran all night you maybe be running a even heat or auto dry cycle. i would first try on a timed dry see if heat then. if does heat (which probably wont) you will be need to replace either the sensor or board that controls the auto dry. or a very small chance that the timers bad. most likely you have a bad heating element. if the machine doesnt heat on the timed dry, then you need to check continuity on the heat fuse(located on heat element housing). if good then check continuity on heat element. i would say you have a bad element or heat fuse.
Aug 01, 2010 | Whirlpool Dryers
I AM A COMPLETE NOVICE---- I HAVE A WHIRLPOOL DRYER THAT TUMBLES AND I BELIEVE IT HAS AN AN EXHAUST BUT THE HEATER ISN'T HEATING UP TO DRY THE CLOTHES NOW THE HEATING ELEMENT DOESN'T LOOK LIKE IT SHOULD BE...
There are some thermal fuses located near the heating element, on the outside of the heating element housing, or some of them have the fuses on the blower housing. Check the element by ohming it out with a meter, if open, replace element. The dryer needs to have an un-obstructed air exhaust shorter then 15 feet from the dryer to vent properly when drying clothes.
Jun 30, 2009 | Dryers
Dryer does not heat air is cold and clothes are not drying
elements are bad or tripped thermostat best if u have a servicer come look at it they know how to check the elements
Jun 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Maytag Performa Electric Dryer, model # PYE2200AYW.
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Oct 18, 2008 | Dryers
Amana DLE330RAW Electric Dryer Logo
298 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
