1992 GMC Suburban Logo
w
weston stanbridge Posted on Jul 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install neutral safety switch on 1992 Suburban located on steering column
Level 3:
  • GMC Master 19,187 Answers
  • Posted on Jul 14, 2014
GMC Master
Level 3:
Answers
19187
Questions
0
Helped
4345117
Points
82261
Under the dash on the steering column is a white piece that looks like a crescent moon. That piece is the neutral and backup switch for the steering column mounted shifter.
5 Related Answers
Anonymous
  • 90 Answers
  • Posted on Apr 18, 2009
SOURCE: why is there an adjustable switch at the base of my steering column
Without seeing the vehicle or knowing the year and model, I would say the shifter is located on the steering column and what you are seeing is the transmission indicator switch, or neutral safety switch as they call it. It is used to keep you from starting the vehicle while in gear. Good Luck, RAC
Anonymous
  • 523 Answers
  • Posted on Aug 21, 2009
SOURCE: replace neutral safety switch on a 1988 gmc sierra
Typically the Neutral Safety Switches are located with the gear selector, either in the column or the floor.
Hope this helps,
Tom
Anonymous
  • 564 Answers
  • Posted on Nov 14, 2009
SOURCE: I need to know the location of the neutral safety
look at the top of the brake pedal you should see it there.
Anonymous
  • 7353 Answers
  • Posted on Mar 19, 2010
SOURCE: where is the fuel safety switch located in a 1999
There is no fuel safety switch, thats a FORD trick. What is the problem?
Anonymous
  • Posted on Jun 23, 2010
SOURCE: NO REVERSE LIGHTS 1999 K2500 CHEVY SUBURBAN-NEW
move the gear selector back and forth between neutral and reverse, but not all the way. have the same problem
2008 BMW 528 neutral safety switch location
on steering column if column shift or floor shift might be there
1helpful
I have a 94 yukon that I need to know where the neutral saftey switch is located at. The reverse lights stay on in park but not in reverse this happened after I, let someone replace the brake booster and I...
Print
REMOVAL & INSTALLATION
The back-up light switch is incorporated into the neutral/park safety switch. The neutral safety switch on 1988-94 models is mounted in the steering column.
Backup light location on a k2500 surburban
Should be part of the neutral safety switch on the column.
Neutral safety switch
Check on the transmission for the neutral safety switch
5helpful
3answers
Where is the netrual safety switch on the column
Don't believe it's there. You have a buick? You must have an automatic? lThe park/neutral safety switch is usually in or on the transmission, and the wiring for it is usually ran through the electrical connector for the transmission. You would probably need a shop to test it, as they would know where and which wires to check. Likely two wires which would have continuity in park or neutral, and no continuity in other gears.
If you want to test it you would need a wiring diagram for your car-good luck.
When i turn the ignition key over the 1994 gmc suburban will not start. then when i turn the ignition key over again the vehicle will start with no problem. i dont do anything between turning the key over....
Neutral Safety Switch ? located at the bottom of the steering column. Mine is tricky, have to pull the shift lever while turning over to get it started. happened after i replaced ignition switch & Neutral Safety Switch
3helpful
Where is neutral ground switch located on the 1991 Chrysler New Yorker.
I am not aware of a neutral ground switch, I presume that you are speaking of the neutral safety switch. These switches are typically located at the lower end of the steering column, and sometimes at the shift lever input on the transmission, itself.
Anything along the shift linkage, from the trans to the steering column locking tube can be connected to this switch.
3helpful
Need location of neutral safty switch on my 1990 cadilac broughm 350 engin e
The neutral safety switch is located on the top and toward the base of the steering column almost to the floorboard.
To remove or install the neutral safety switch be sure to place the shifter in the neutral position, then dis-connect the wire connector at the neutral safety switch, then remove the securing screws and then remove the neutral safety switch.
Install the new neutral safety switch and do not over-tighten the securing screws, then remove the alignment pin and re-connect the wire connector to the neutral safety switch. (be sure not to remove the alignment pin until the neutral safety switch has been installed)
Check to be certain that the vehicle only starts in "Park" or "Neutral". Here is an image to help assist you, and let me know if you require any further assistance.
2helpful
1971 ford f100 pickup neutral safety switch wiring color code
Ford Neutral Safety Switch; Ford Reverse Light Switch; Backup Light Switch.
The Neutral Safety Switch wires in my 1971 Ford F100 are orange with a blue stripe.
The Reverse, or Backup Light Switch wires are black with a red stripe.
There are two sets of two wires across this combined neutral safety and backup light switch, for a total of 4 wires. Photos are at the end of this post.
The switch for the 1971 Ford F100 pickup truck is the same as in many other years and models. For details, including parts numbers, see the following quote from an expert at Ford Truck Enthusiasts:
http://www.ford-trucks.com/forums/287185-back-up-light-and-neutral-safety-switch-2.html#post5601846
The neutral switch also controls the backup lights, and is the same 1967/77.
C7TZ-7A247-A .. Neutral/Backup Switch (Motorcraft SW-600)
There is no separate backup light switch..except on 1967/68 F350's.
Neutral switch location 1967/77:
The plastic half moon shaped neutral safety switch mounts on the outside lower portion of the steering column (NOT on the transmission!).
It's activated by an inverted Y shaped lever that snaps on the shift tube
D0TZ-7B097-B .. Lever, Neutral Switch Actuator = From FTE sponsor DIRECT FORD PARTS: Ford suggested retail price: $18.72 / FTE member net: $13.23.
The switch is also still available from Ford, but the website is down so I can't post the list & net prices. .
1978 is the FIRST year the F100/350's have the neutral switch mounted on the transmission. __________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
IMAGES
Driver side of the neutral / reverse switch showing the travel slot for the switch arm, the return tensioning spring, and the arm.
The front, steering wheel side of the neutral / reverse switch after removal from the steering column. The switch's two functions are actuated when the lever in the column moves the switch lever shown here to different positions as gears are selected.
The neutral switch is installed on the steering column near the firewall, with 5/8" bolts into the steering column (visible hole) and down column from a rectangular opening in the column housing. The actuating lever for the switch is attached to the gear shift shaft inside the housing; the lever is visibly protruding from the opening in this image.
Back of neutral / reverse switch, showing the wiring attachments. Black with red stripe is the backup light wiring, Orange with blue stripe is the neutral safety switch, it prevents starting in gears other than neutral & park.
9helpful
6answers
1992 buick lesabre ignition problems
do you get a "security" light in the dash?
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
