Question about Acer Aspire 3680 Laptop
I have a wireless connectivity issue from my laptop. When the power cable is connected, the internet works. When I disconnect the power cord, I am disconnected from the internet. This problem has only started after a couple of years with no issues. Many thanks, Danielle
  • 258 Answers
I would say you need a new battery, if when you disconnect the charger your losing your wireless connection, you need more power to hold the wireless connection or that make sure when you remove your charger press your wireless button near your volume control on laptop to make sure its on, blue, not off red ok
Posted on Jun 29, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
Cannot get eee pc 1001pxb to connect to the internet. it has connected to a wireless internet, but not the wired connection. I have linksys wireless g router, but it is hard wired to all my computers. i...
Good Morning.
Do not worry, We will fix the issue for you.
Please open control panel >> network and sharing center >> if you see wireless network connection >> please disconnect it and >> connect the lan cable or wired cable to the laptop and start browsing.
This will fix the issue.
Jul 06, 2011 | ASUS Eee PC Netbook
I pruchased a Sony VAIO VGN-TXN15 Notebook from a guy on ebay who said the notebook worked well. Unfortionatly It does not connect to the internet wireless or with the eithernet cord. I took it for a...
Did you tried cable connection to your router to see if this works?
which windows its runing on?
If wireless connection drops its not all the time your laptop issue... its router transmitted channel conflict with laptop wireless card channel....
You might fix this by changing the router wireless setting by changing the transmission channel on it.and then re connect the laptop or it may auto reconnect with it and hopefully signal will not drop.
one is network card for cable connection to internet
one is wireless card for wireless connection to your router(with internet connection)
I will write more after I get your reply. As I am in the middle of my own issue now... ;)
May 08, 2011 | Sony VAIO VGN-TXN15P/B Notebook
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
Apr 30, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless laptop disconnects from internet when power cable connec
Does it reconnected again then? Or it never reconnects on the AC? I would try different channels on the wireless router first. Hopefully that will solve the problem do to some interference. If not, report back and I have other things you can try.
Jan 15, 2009 | Acer Computers & Internet
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Keep getting disonnected from internet when using laptop power cord
weird problem you got there huh, just try to reinstall the wireless or built in lan card driver, is the power adapter near the lan cable outlet? maybe its just loose, try to use wireless connection in the internet
Apr 05, 2008 | Computers & Internet
My wireless is not working...
You will have to remove the cable from your wired card first, as your pc cannot open 2 networking ports and obtain an ip address. The wireless card needs to be able to pick up the address and dns address from the router, so when your disconnected from wired card, your wireless should search for wireless connections and allow a conection.
Feb 23, 2007 | IBM ThinkPad T21 Notebook
Acer Aspire 3680 Laptop Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
