Question about Microwave Ovens
Microwave oven not working model sharp R-38ST
When trying to use the microwave oven, the light comes on the microwavr turns around but no heat is produced, therefore doesnt cook the food.
  • 5 more comments
  • Anonymous Dec 14, 2007
    everythin works but no heat,I replace fuse blown.
  • chantellemcl Dec 26, 2007
    my microwave will allow you to set the cook time but when you press start the unit counts down the alloted time but doesnt cook . Yes it is on the cook setting not the timer.
  • Anonymous Apr 21, 2008
    microwave turns on although the it does not cook anything
  • Anonymous Apr 30, 2008
    Did changed the magnetron and capacitor is okay but first you turned 0n it work okay. Then tried again no heat. Pls. help what is the problem. This is a Sharp mocrowave oven model # R-408HS.
    Thanks.
    ed
  • Anonymous May 16, 2008
    I have a Sharp R-408HS 11000 Watts. Everything works in the command panel, however, when its ready to heat the food, the darn thing won't even start. Could it be a bad fuse?
  • Gainmel Nov 07, 2008
    I put a cup of water in the Viking Microwave, Model # VMOS200. Set the timer for 20 seconds. The light comes on, timer runs down, the turn plate does not turn and the water does not get hot. I removed the cover, checked for power to the PC Board and fuse which are good. All grounds are good. No power coming out of PC Board. I sure the PC Board is bad. Can anyone confirm this?
  • dangerboy12 Mar 12, 2009
    The microwave seems to be working fine, but it doesn't heat the food at all. The lights work, the display and the keys work, the turntable works, and it's on power level 10. Just no heat.
  • Microwave Ovens Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 18, 2007
My dcs mo-24-Ss microwave oven cannot heat the food after turn on, everything working fine other than no microwave come out
Assuming the turntable, inside light, and internal cooling fan all work when you press "Start" to cook, then I would suspect a bad magnetron, or a bad connection at the "FA" terminal of the magnetron.
If one or more of those three items do not work when you hit "Start", the I would suspect a bad door switch or mount.
The DCS MO24SS is essentially a rebranded Sharp R-530E-series microwave with different cosmetics and a higher price.
The service manual for the Sharp model is here.
The internal Sharp parts in the manual will interchange, but not the external cosmetic parts.
You can order Sharp parts from Encompass here.
Nov 22, 2012 | DCS MO-24-SS Microwave Oven
Sharp microwave oven R-580D will not heat or defrost
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hljk
Mar 12, 2010 | Sharp R-1480 Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp microwave model #1872
Most likely the lower door interlock switch is bad. Cheap and pretty easy repair.
Martin Microwave Inc. sells the switches for around $5....
www.martinmicrowave.com
Oct 27, 2008 | Sharp R-1870 Convection/Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
