Question about RCA OPAL M4001 MP3 Player
The screen is locked
The screen says keys locked how do i change this I hit the reset button in the back this did not help
THERE SHOULD BE A SIDE BUTION AND IF U MOIVE IT DOWN IT SHOULD UP LOCK
Posted on Jun 30, 2009
How to unlock screen lock
use the dial to make your first numeric selection. hit the center button. do it again 3 more times. once you hit center the last time and the lock code is right, you will enter your iPod. to travel backwards nit the l<< key to go back a previous dial to change a number.
Sep 03, 2014 | Apple iPod nano
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
I locked myself out of my cricket zte. How do I unlock myphone if I forgot my password?
This happened to me.... before you do this beware that your entire phone will reset... ok...let's get started.. while your phone is off hold the volume up button, muve music button and started button all at the same time until a yellow triangle shows up...next let the buttons go and press the up and down volume buttons until the reset screen pops up...use your volume keys to navigate to factory reset and hit enter with the muve music button.. itshould ask you if you want to reset your phone so scroll down to yes.. after this it should say at the bottom wipe successful or something of that nature... the phone should then cut off and cut back on itself.... that should do it.. hope this helps.
Apr 12, 2012 | Cell Phones
I can not find my pass key
hit the rest button on the back of the unit. you will have to use the default ushally just hit enter but then you can make changes lock it up again and you will be all ready again this time write the password on a peice of tape or something you can stick tot he bottom of the router
May 29, 2011 | Linksys Wireless-G WRT54G Router
How do I change the waste ink absorber in a canon ink jet printer
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 28, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
How do I reset the code? I just moved into a house that has one but no instruction manual.
On the inside under the back plate you will find a button on the bottom left. Press button once enter you code 4-8 digits. Then press lock. Re-enter the code. If it unlocks you code is entered. This unite can keep two codes. To set the second code hit the back program button twice and follow the above directions. Also not the key lock is a Smartkey sysyem so you can change the key also.
Nov 16, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
My g1 phone has locked and wont accept my username and password. I have changed the password on line and checked it works but cannot get my phone to unlock
Okay the thing here is you need to master reset it.
Here's how it works:
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the QWERTY keyboard and hit Alt+W
  4. Restored!
To do a soft reboot, simply hit the Home+Back buttons when you reach the "triangle with an exclamation point and a picture of the G1" screen.
This will reset your phone as if it were brand new and your correct user name and password combination will work.
(This is coming from a direct T-Mobile employee)
-Joe
Oct 22, 2009 | HTC G1 Smartphone
THE WINOWS STARTUP SHOWS ON SCREEN ON/OFF BUTTON IS BLUE
Is your keyboard also wireless? Check batteries on all wireless devices. If batteries are fine, restart your computer (hold down your power button until your computer shuts down unless you have a reset button) and then try unplugging and plugging back in your wireless receiver, then hit your connect buttons starting with your keyboard followed by your mouse.
May 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Unlock security Code Kenwood KDC-MP3035
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Mar 26, 2009 | Car Audio & Video
Locked myself out of my mogul
You may have to do a hard reset.
You do this by:
Holding down both left and right soft keys (the buttons above the red and green phone keys) while pressing the reset button (on the bottom of your phone) with the stylus. Hol down the soft keys until you see a message asking if you want to reset. You then need t slide the keyboard open and press the appropriate key.
Warning: this will reset your phone to manufacturers settings; all data will be erased. Your phone, however, will no longer have a password, and you will be able to set a new one.
Feb 13, 2009 | HTC PPC-6800 Smartphone
RCA OPAL M4001 MP3 Player Logo
48 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
