Question about Magic Chef 9122 Gas Single Oven
Oven will not light. burner won't even light if I try lighting it with a lighter. I thought maybe it was the igniter but am wondering if the burners go out on these. This is a problem that has been getting worse. At first it would just take a long tome to light and sometimes I would light it with a lighter if I started smelling gas too badly but now it wont do anything.
  • Magic Chef Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
fdfsd
Posted on Sep 30, 2010
How do I lite the oven pilot
If it's an older model with a true pilot light you turn on the gas at supply line valve, open oven door, remove bottom panel to access pilot and burner. Sometimes it's easier to remove broiler drawer on these models but regardless take a lighter and light pilot. Most models are electronic ignitions which if you have it probably needs replaced if it doesn't ignite the burner in under a minute or minute and 15 secs. It could also be a bad thermostat if the burner ignites within the time period described above
Sep 10, 2014 | Magic Chef Ovens
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
Oven burner doesn't light. Igniter doesn't light. Boiler burner does light and Igniter does light
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Mar 01, 2010 | Maytag Ovens
My gas was recently shut off for repairs from the gas company, now its back on and i dont know how to get my oven or stove back on
Ok you did not mention if your oven or stive had pilot lights or igniters. Given you asked the question how too turn it back on I have to assume it does not have electronic igniters. You need to light the pilot lights. There are 2 in top that are between each of the 2 burner sets. If you can not gain access to the pilot light by lifting the top of the stove up you can use a fire starter type lighter and re-light them. Sometimes they will self light if you just use a match on the burners.
As for the oven you can gain access 2 ways to the pilot light. One is to unlatch and remove the oven lower inside panel. The pilot light will be near the burner head. Just light it. The other is to remove the broiler drawer and reach way back in there to light the pilot light.
Again if you have igniter ignition all you have to do is turn on a burner or the oven. Good Luck.
Jan 22, 2010 | Ovens
Gas oven is working fine but none of the burners are igniting
The little gas ports maybe blocked on the burners, try cleaning the ports, also on the burners there are 3 or 4 small pin holes for the gas to travel, a small paper clip will remove any debris trapped inside these holes once they are clean the burners should light
Oct 30, 2009 | Ovens
One or more igniters are trying to light burners that aren't turned on .One burner is on. The other post on this never got answered properly.
When you turn the burner dial, all igniters spark. Most brands work this way. The dial activates all igniters to spark but only opens the gas valve attached to that dial.
Do you mean that they continue to spark even when you are not trying to light the stove?
Jul 28, 2009 | Jenn-Air JJW8530C Expressions Collection...
Burner not lighting but igniter is glowing red hot.
The flame sensor is not activating the gas valve. Check or change sensor.
Jul 22, 2009 | Maytag CWG3100A Gas Single Oven
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Magic Chef 9122 Gas Single Oven Logo
157 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
