Question about Panasonic Lumix DMC-FX01 Digital Camera
The camera will turn on but the lense will not open
  • 73 Answers
The problem on ur camera lens barrell u chaing the lens unit
Posted on Jun 29, 2009
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn on my DSC W55 the lens does not open all the way. Is better to fix it or buy a new camera?
It usually cost more to repair digital cameras than investing in a brand new one. Before you decide to trash your camera and buy a new one try this.
Some dirt somhow gets on the outside of the lense and they would prevent the lense from opening or closing 100% as it normally does.
Clean around the lense and turn your camera off and on a few times. If the lense opened out 100%, you should be able to take pictures as you usually did. If NOT
turn on the camera and help the lense to open up by pulling the lense out NOT too hard. If the lense goes up and down you follow the lense motion (up and down and turn). If the lense opened up 100%, then turn the camera on and off a few times, it may work now.
If you have dropped the camera, some mechanical part of the lense mechanism is broken or disslocated. In that case, the lense has to be opend from the camera, inspect for broken parts or loose parts, and clean it up. If you put it back on the camera, it may work. Remember opening the lense is the absolute last thing you want to do. Most likely, you would make it worse than, before opening it.
If you decided to buy a new one and trash this camera, please send the camera to me. I will pay to you ONLY your shipping cost. I would try to fix it and learn more about the problem your lense have. I would be able to help the next person with the same problem better. my email address pourmp@yahoo.com.
GOOD LUCK !!!!!!!!!!!
Jun 15, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
S630 won't turn on
Openings the lense is the last thing you want to try. If you dropped your camera, you may have to. If you did not drop your camera, some dirt somhow got on the sides of the lense and they prevent your lense from closing or opening 100%
Try this first
turn it on and the same time pull the lense out. Your lense may not be open all the way out. OR
Clean the side (outside) of the lense. While turning your camera OFF, push on the lense in NOT too hard. Try that a few times, If the lense retracted 100% or near 100%, just push the lense in a little harder untill it is 100% retrected. Turn it on, It may work now.
Good luck!!!!!!!!!!
Good Luck!!!!!!!
Jun 11, 2009 | Samsung S630 Digital Camera
MX1063 will turn on and lens comes out, but immediately turns off and lens goes back in. I charged it for hours and still nothing.
The outside of the lense may be dirty. When it comes out clean it. Or something else prevents it from fully opening. If it is clean, you might have droped it and damaged or broke mechanical part(s) of your lense. When it opens, try to hold the lense open, do not force it. If the did not help, take out the lense from the camera and inspect the lense. look for broken, or bent parts. Clean it and push the lense in and out. If it moves in and out without any problem, put it back on your camera. If the problem was from the lense, your camera should be back to normal.
Good luck!!!!!!!
Jun 10, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony cybershot 7.2 went to shut off camera and lense is still out no power to camera tried to recharge batt. w/no results
Try different batteries. I got the same problem with my cyber-shot. The battery was too low while lense was fully open. I recharged, but the lense would not close. When I turn it on, It would say turn off and on again. I did that for at least 20 times. I finally put another set of batteries and while I turned off the camera, I pressed the lense in very softly. After a couple of times the lense retracted fully. The camera has been working normally ever since.
It is also possible some dirt some how got on the sides of your lense. Try cleaning the sides of the lense.
If you had no luck so far, then your lense may have some mechanical problem. The lense need to be opened and cleaned and put back together.
good luck
Jun 09, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
In camera or video mode it says turn the power off and on again
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
If the lense does not retract, but goes up and down when you turn it on or off, Clean the sides of the lense and while turning the camera off push the lense in NOT too hard for a few times. If it retrected 100% or most of the way inn, push the in a little harder untill it is 100% retracted in. Now your camera should be back to normal. 2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damaged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Apr 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
80 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
