Question about Technics SA-EX500 Receiver
The yellow reset/help button is flashing, nothing else is lit up
We are an orthodontic office; we are connected to Muzak with two separate bands - one for the front of the office and one in the back. No sound is coming from the Technix Receiver, just the yellow flashing reset/help button. We have unplugged everything, it still flashes and no sound. We also have a cd player connected to the receiver, the cd's are playing but no sound
  • 883 Answers
SOURCE: MP3 connection to receiver
absolutely! any audio device using wires can. connect the RCA plugs into the back of the Technics "LINE IN" jacks...the MP3 end may be a 1/8" mini stereo plug (widely available complete cord)
Posted on May 30, 2007
  • 4234 Answers
SOURCE: bad sound when running signals through
I would guess that the switching chip is faulty inside the receiver. Since the CD works OK, the amplifier section and pre-amp section are good. What you are hearing with the others is crosstalk. This chip shouldn't be more than about $10-$15. Add in the local labor rate for the total repair cost. I think that the chip for your model is a TC9163.
Dan
Posted on Jun 02, 2008
SOURCE: Technics SA-GX490 reciever
Disconnect receiver from power and open the unit. Localize fuse that is placed on small PCB between main transformer "big one" and rear panel.Fuse's amperage is 1.6 A .I'm quite confident that fuse is gone.If so, replace it with the one of same amperage and try unit.
My unit has done exactly the same to me with no reason.
Radek
Posted on Oct 04, 2008
  • 92 Answers
SOURCE: Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
Posted on May 19, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
D Link Not Working
Check the router internal setting under the WIRELESS SETTINGS section. The 2.4 and 5 GHz bands are separately enabled. It's possible the the 2.4GHz band may be disabled. Also check under ADVANCED WIRELESS SETTINGS to ensure that the TRANSMIT POWER level is set correctly. If that is not the problem, check to see if you have recently located any electronic wireless device near the router that can interfere with the band. Many cordless phones use that band and can interfere with transmission and reception. Finally, if nothing else works, I would record all router settings and attempt a router reset to see if that solves the issue. Otherwise, it would seem to be a failure of the router.
Nov 04, 2013 | Computers & Internet
On my HP Business Inkjet 1200 the black/magenta/yellow lights are flashing but not the cyan. Neither the printhead or ink cartridge light is lit. With 3 out of 4 lights lit what is the printer complaining...
You may be using non original ink catridges, the printer chip will not recognise so flashes as if needs replacing.if refills are original printer chip may need to be reset.
Feb 03, 2018 | HP Business Inkjet 1200dtn Printer
How can i have music in hold time ?
There are several ways to have music-on-hold for your telephone line(s). 1st you need to have a source of music such as a radio that has an output connection to feed the radio signal to the tele system, or a recorded music player that also has this output connection, or you can subscribe to Muzak (www.muzak.com) a company located in South Carolina that provides this type of service. 2nd, you need a telephone that has the input connection to allow this music source to be connected to the tele system, or you can buy a music-on-hold adapter that will feed your music source into the tele system regardless of the type of phone you have (as long as the phone has "on hold button", or if you choose Muzak, they will provide this aparatus adapter to you. Check the manual that comes with your phone to see if it has this music input feature; I'm not 100% sure of your model without further research, but I feel that the phone most likely does not have this feature. An adapter unit can be found at Radio Shack, or some AT&T telephone stores or on the internet. Good luck, Macgivor.
Oct 04, 2009 | Panasonic KX-TS3282 Two-line Corded Phone
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a yellow blinking toner cartridge light. Neither the continue or cancel lights are lit up. This...
Sounds like your photocoductor is at lifes end. You can reset it by doing the following
1. Turn the printer off.
2. open the front cover
3. hold down the cancel X button while turning on the power and keep holding down until all lights stop flashing. Then let go of the x button and all lights should start to flash, close the front cover...and it should reset. You may have to turn the printer off and then back on once to be sure it is reset.
Jul 07, 2009 | Lexmark E232 Laser Printer
Brother HL-5050 paper flashing yellow
Have a look in the back of the machine. There could be a sheet in the fuser.
Oct 17, 2017 | Brother Office Equipment & Supplies
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
Won't turn on -- has a yellow question mark lit -- what do i do? HP Office Jet Pro L7680. Only thing lit is a yellow question mark.
here are the steps that i want you to follow.
PERFORM SEMI-FULL RESET
  1. While the Unit is turn ON, Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 6 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
Please, let me know if the steps resolve your issue.
Thank you so much.
adonscott
Jul 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
73 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
