Question about Rainbow E series Canister Wet/Dry Vacuum
My rainbow shuts off after about 2 minutes - Rainbow E series Canister Wet/Dry Vacuum
  • 75 Answers
It could be the switch . my electrolux has the same problem but wont always turn on.so it probably is the swich.
Posted on Jun 29, 2009
Rainbow turns on for a second or two then quits and won't turn back on.
If you have the model Rainbow E-2 eSERIES then the Motor Rainbow 120v could be going bad. This will trip the auto reset until it cools down.
If you have an E2 Type 12 Rainbow, then the Controller Asm 120v e2 Silver Gold could be going bad.
Our technical support team is available if you need... Contact Us
RainVac
Mar 24, 2016 | Rainbow E series Canister Wet/Dry Vacuum
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Rainbow E series vacuum shuts downs
When a bearing or the motor brushes go out it will cause the motor to shut down like this. If this is the case and you continue to try to force it there will be potential damage to the armature.
Jul 26, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E Series vacuum will run for a few minutes then shut off
There's something wrong with the engine get a new one.
Jan 31, 2014 | Rainbow Vacuums
Rainbow Overflow .. HELP
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 2 speed vacuum shuts off after 5 minutes of vacuuming.
2 speed E2 models have a circuit board inside that controls the machine. It sounds like this controller board may be bad. The unfortunate part of this is that the board is not only very expensive, but it is only available from an authorized Rainbow service center.
Use caution if you decide to work on this yourself or if you take it to a service center that is not famliar with these models. The circuit board mentioned above is susceptible to damage from static eclectricity discharge. The static you generate from just walking across a carpet could make this board useless. So, if the original problem is not the board you could make the problem worse.
Jan 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
New Rainbow aquamate. It is not letting the water flow through.
Sometimes it takes up to 10 or so minutes for the Aqua mate 2 to begin pumping out anything.
If it is the new Aqua mate 12 (the big blue one, that is like a giant power head) the same thing is true for it.
Thank you,
Ralph
Dec 22, 2009 | Rainbow E series Canister Wet/Dry Vacuum
VACUUM RUNS FOR A MIN AND THEN SHUTS OFF
It sounds like a problem with you motor. The hepa filter has nothing to do with the motor, and should not have been removed. It sounds like the repair man doesn't know much about rainbows. It could be a short in the motor housing or faulty/improper wiring. It may have happened after it when it was worked on the first time. Is it similar to the problem you were having before?
If you bought it from a rainbow dealer, you need to contact them, you should have a warranty, depending on when you bought it. If it is still under warranty, they will fix or replace it for free. If the warranty has expired, they may be able to work out a deal to get it fixed or may be able to direct you to a rainbow repairman.
Aug 09, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I have my vacuum set to shampoo a rug, but cannot get the water to come out
If it is an earlier model Aquamate, then it is clogged somewhere in the hose, or the fluid control valve is clogged.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 25, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
349 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
