Question about Bugaboo Cameleon - Tailored Fabric Standard Stroller
Handle will not lock in place when handle is large wheel(front) side yet will lock in place when in small(back) side.
2 Suggested Answers
  • 20 Answers
SOURCE: Bugaboo Frog Handle Won't Lock in Place
Hi
Visit www.buggypitstop.co.uk/ they can help
thanks
Posted on May 05, 2010
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Toyota Tazz window winder
Toyota Tazz driver side window refused to wind properly. Problem was that winder mechanism and window separated - old glue. Found some input from Ben on this forum. Some pointers after doing the job today.
Step 1 - remove the arm rest - two screws
Step 2 - remove the screw holding the door opener handle.
Step 3 - remove the C-clip holding the winder handle. The clip is round but the ends are slightly bent outward - to fit back easily. Use a large screwdriver to force a small opening (thus moving the panel slightly inward). I took a piece of thin solid wire and bent it into a loop. This looped wire I hooked around the one end of the clip and pulled in the opposite direction towards the inside of the car. The open end is towards the part of the handle you wind. Make sure the top of the handle faces towards the interior of the car (door is open wide). The clip shot off (as Ben warned) but landed in the car.
Step 4 - the door handle (square) must be slid forward and outward towards you. Will now be loose but is held by the rod going to the lock.
Step 5 - loosen all clips carefully by pulling the panel forward - large screwdriver works.
Step 6 - lift up the panel - and push the door handle holder through the hole in the panel. The panel will now be free.
Step 7 - the window can be removed in this case where window and mechanism seperated by simply pulling the window upwards and outwards.
Step 8 - I used a small grinder and removed most of the glue - but not all.
Step 9 - put the window back into the door making sure it is correctly aligned in the side-sliders.
Step 10 - I used an epoxy 2-part glue (Pratley) and placed some glue in the holders. Position the window and mechanism correctly (using glue I left as marker). Note that only 2 holes in door panel can be used to see or fit glue.
Step 11 - Mix more glue and apply front and back. Now place some grease in the mechanism rail (horizontal) and wind window to the top. Leave to dry.
Step 12 - replace all in reverse. Clip pushes on easily - I used a small long-nose pliers.
Cheers,
Chris Snyman
Nov 20, 2012 | Cars & Trucks
How do you change the handle direction, we have the small wheels at the rear and would like them to be at the front
Just use the handle release buttons to un-lock the handle and swing it over to the other side than release the seat by pressing the two square buttons and turn it around so baby still faces you. www.fixya.com/support/r9134331-assemble_frog_or_cameleon
Aug 30, 2011 | Bugaboo Frog Stroller
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
Can not raise the handle bars on the Huffy Mojava Gulch?
You need to loosen the front bolt that holds the handle bars to the front wheel raise it to your desired position and then tighten it again, making sure that the handle bars are at the position you desire them. This will lock them in place so you can ride your bike and not let them fall back down deeper into the front wheel shaft.
May 11, 2011 | Huffy 26 In Ladies Mojave Gulch Bike
Stroller is folded over and we can not bring it up to sitting position
Not sure if you mean the handle is locked up and won't move or the seat is locked up and won't move? The front and rear wheel units are locked by the seat unit. The handle has two release buttons that have to be opperated at the same time to release the handle. The seat tilts by pressing the large white buttons on the side. Let me know what part is not working and I'll try to help.
Jan 07, 2011 | Bugaboo Frog - Black Stroller
My bugaboo keeps pulling to one side? What's wrong with it?
First check that the handle extension locks hold properly and the handle is not slipping on on side. A handle lock problem (the part that allows the handle to swing from back to front) should be obvious but check both are locking and have the same amount of play. Finally check all four wheels spin freely and the smaller front set can both rotate freely. Your Bugaboo maintenance kit came with a small can of silicon spray. Use it regularly (once every month or two) to lubricate the handle lock, brake lever and wheels. If you find a specific problem let me know and I'll try to help.
Nov 17, 2010 | Bugaboo Cameleon - Tailored Fabric...
The stroller wants to turn to the right, it wont stay straight.
Turn stroller upside down (sans baby ;-) First spin each back wheel to check it turns freely and it's fully engaged into the chassis. Front wheels should spin easy and rotate 360. If this is all good check the handle locks, are both sides locked or is only one side locking causing the handle to twist and put uneven pressure on the chassis.
Nov 01, 2010 | Bugaboo Cameleon Stroller
Hi
thanks
May 05, 2010 | Bugaboo Cameleon Jogger
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Bugaboo Cameleon - Tailored Fabric Standard Stroller Logo
35 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
